Educate me on the ways of Zaino
Old May 2, 2004 | 05:23 PM
Bass4life04's Avatar
Bass4life04
Default Educate me on the ways of Zaino
How much is this stuff and what do i need to get started? Is it truely worth it? Once I start will I be able to let go and walk away?
Old May 2, 2004 | 05:58 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Default Re: Educate me on the ways of Zaino
Here is my Zaino tutorial with my "bare essentials" list. I have posted it before but here goes again:
Bare minimum Zaino products:
Z-6 (two bottles)
Z-2 (one bottle)
Z-5 (one bottle)
ZFX (one bottle)
You can use any mild carwash but the Zaino Z-7 is best. It is pH balanced and cleans very nicely without removing any of your Zaino polish.
Also, nice to have (but not essential) are the Zaino Tire Dressing (Z-16) and the Claybar (Z-18). Zaino makes a nice leather seat product, a plastic cleaner, a window cleaner and several other non-essential products.
Here are the initial steps of the Zaino process (at least how I do them)
-Wash with Dawn dishwashing liquid. Use a non-scratching wash mit. I use a microfiber mit. Make sure it is completely free of dirt and debris. Make sure your bucket is completely clean too.
-Rinse
-Clay the car with a solution of Z-7 and water. A quart of water and a cap full of Z-7 should do it. I use a clean spray bottle to spray it on the car. Do small sections at a time. Make sure the clay glides over the paint easily and doesn't stick. If it does, spray on more lube solution! Continue to knead the clay to keep a clean fresh surface against the paint. DON'T drop the clay! If you do, toss that bar and get another one.
-Wash with Zaino Z-7 carwash. Do the tires/wheels first and then use a separate bucket of suds to do the rest of the car.
-Rinse. After you are done rinsing with your spray nozzle, remove the nozzle and rinse the car with the stream of water from the hose only (no nozzle, no thumb over the hose). Use the stream of water to "push" off the beads of water. This is a neat trick that will decrease your drying time significantly!
-Dry the car with a microfiber towel. I prefer the waffle weave microfiber towels. I like to use a shop vac to suck out drops of water in tight areas that you can't get with the towels. Make sure you don't touch the car with the vacuum hose.
-Do a Z-6 misting. It's just like using Windex on windows. Just spray on a light mist of Z-6 detailing spray and wipe it off (in). You don't let it dry, just take it right off. I use the Z-6 on all the glass as well. It cleans well and rain zips right off of it.
-Apply your first layer of Z-5 polish. You can add 2-4 drops of ZFX "flash cure" accelerator to ONE OUNCE of polish. If you do this your drying time with be decreased to one hour or less depending on the temperature and humidity. I use 2 if it is very hot and dry and 4 when it is colder and humid. I recommend applying Zaino polish in the shade but it will work fine in the sun as well. It will just dry a lot faster. Take note that the small mixing bottles you get from Zaino with your order are TWO OUNCE bottles so you only fill them half way up (one ounce). One ounce will do the entire car easily. In fact, if you apply the polish thin enough (and thin is the best way to apply it) you can get two layers on the car with one ounce. Zaino shouldn't look like wax on a car. In other words it shouldn't look hazy and white. It should look like the color of your car only a little blurry. If it looks the least bit white, you applied too much.
The other way to go at this point it to not use the ZFX flash cure and just apply the polish to the car. This is fine only it will take a good 6-8 hours to cure on the car and this will limit the number of layers you can get done in a day (or weekend). I often do two layers with the ZFX, and the third one without it. I apply the last one at night and let the car sit in the garage all night and remove it the next day. You can tell if it is ready to remove when you smudge it lightly with your finger and it ALL comes off and leaves a very shiney surface behind. If it is the least bit blurry it isn't ready yet.
The polish goes on with the applicator Zaino sends you. I like to slightly dampen it first with water. It helps to apply it a little smoother and evenly this way. I recommend side to side straight line applications on the horizontal surfaces of the car (hood, roof) and up and down straight lines on the vertical surfaces (doors, quarter panels). Do not use circular motion (swirls) to lessen the chance of scratches and swirl marks.
-Buff off the polish with a microfiber towel.
-Another Z-6 misting
-Repeat another layer of Z-5 (with or without ZFX)
-Buff off
-Z-6 misting
-Final layer using Z-2 this time (with or without ZFX)
-Buff off
-Final Z-6 misting.
This is my method. You don't HAVE to do all three layers nor do you HAVE to do all the prep work (the Dawn and the claybar) but you will get a MUCH better result if you do them. Many feel that the Zaino process is too complicated and involved and want to use "easier" products. It is important to realize that the prep process is NOT exclusive to Zaino. It should be done with ANY product for best results. Also, you don't need to do three layers or even two for that matter. If you want to do just one, go for it!
For maintenance all you need to do is wash with the Z-7 and do a quick Z-6 misting after you dry. This is enough to keep your ride looking great between your BIG detailing sessions.
Good Luck!
The Doc
Old May 2, 2004 | 07:35 PM
Bass4life04
Default how long will that last
So how BIG detailing sessions the
Z-6 (two bottles)
Z-2 (one bottle)
Z-5 (one bottle)
ZFX (one bottle)
last? cause thats like $60 right their and im a poor student...
If that will last me a year sounds great, but if its gonna cost me several hundred a year to keep my car looking great i think ill pass. Thanks in advance
Old May 2, 2004 | 09:34 PM
dchengmd's Avatar
dchengmd
Default Re: how long will that last
Z-6 (two bottles)
Z-2 (one bottle)
Z-5 (one bottle)
ZFX (one bottle)
The list you supplied above should last you at least a year if you apply it on the car once every month or so. You don't need to apply Zaino after every wash, but I would recommend using the Z-6 every time.
Even if you apply Zaino more frequently (like every 3 weeks), it shouldn't cost you "several hundred a year".
Old May 3, 2004 | 03:45 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
If you do the detailing session I described above only ONCE a month, that amount of product should last you at least a year.
Old May 3, 2004 | 08:40 AM
mrZeee's Avatar
mrZeee
Default Re: Re: Educate me on the ways of Zaino
Z-6 (two bottles)
Z-2 (one bottle)
Z-5 (one bottle)
ZFX (one bottle)
-Rinse
-Buff off
-Z-6 misting
-Buff off
-Final Z-6 misting.
Good Luck!
The Doc
where are the cliff notes to this book of all that is Zaino???
Old May 3, 2004 | 06:44 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Here they are:
Apply, buff of, repeat.
Old May 3, 2004 | 10:05 PM
mrZeee's Avatar
mrZeee
LOL
Old May 4, 2004 | 03:11 PM
Reggi914's Avatar
Reggi914
wow doc, your car is glowing in that pic!
Old May 4, 2004 | 07:47 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Must be the new Zaino U-5 with added Uranium. Ask for it by name!
Old May 5, 2004 | 05:58 AM
Dustin4u's Avatar
Dustin4u
holy shine.
I LOVE the tire dressing. The leather protector is great also.
I'm not a fan of the claybar. My car was right off the train mind you and i clayed it....did NOTHING at all. No specs in the clay what so ever.
The clay is/was pretty much rock hard...... mabye defective?
Old May 5, 2004 | 06:48 AM
touring's Avatar
touring
I asked this in another post but didn't get a clear answer, If the shine is compariable or even better in some cases and its best benefit is its longevity, then why extra coats after each wash?
Old May 5, 2004 | 07:11 AM
BEAVR Z's Avatar
BEAVR Z
With each coat your finish will deepen and become smoother. Increased layers also provides additional protection. Sure it chews up your weekend but its worth it and if you hand-buff its a great shoulder workout
Zaino On! Zaino Off!
Old May 5, 2004 | 08:09 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
"...then why extra coats after each wash?"
For the love of the game!
Old May 6, 2004 | 08:52 AM
KShep's Avatar
KShep
Bass4life04:
If you are concerned about costs, be sure to factor in purchase of the correct towels for drying & buffing the finish. While not overly expensive, they are an important part of the equation, no matter which product you intend to use.
While the INITIAL procedure is time comsuming, follow up applications can be done in much less time and the results are both longer lasting and better for your paint than silicone based products. "Just get some on there"...you will be rewarded for the effort & moderate expense.
>>"plagiarized from Dr. Bonz"<<
(sorry I don't have the link for towels at hand, scrolling thru this section will get you to one)
Old May 6, 2004 | 10:46 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
www.dftowel.com
Old May 6, 2004 | 07:19 PM
The Sopranos 16's Avatar
The Sopranos 16
www.dftowel.com
I checked out the site. I have three questions for you Doc:
1) It says something about about My350Z.com members getting a discount with a code, whats the code?
2) How do these towels compare to a quality cotton towel such as Fieldcrest (which Zaino reccomends)?
3) How do they compare to a quality microfiber towel?
Old May 7, 2004 | 06:15 AM
KShep's Avatar
KShep
The DF towels are perfect for detailing. They are easy to work with and come in 2 sizes. Here is a link explaining the differences between microfiber & 100% cotton...
https://my350z.com/forum/showthread....threadid=62970
Old May 7, 2004 | 03:36 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
It's been a long time but I think the code was just 350Z or my350Z. Anyone else know?
I think the MF towels are INFINITELY better than any other towel. Unless you have debris stuck in them, it is almost impossible to cause swirls. You can't describe just how soft these things are without feeling them for yourself.
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
Depravity
Oct 1, 2015 04:49 PM
