Question About NXT
Old May 27, 2004 | 04:42 AM
Ricky's Avatar
Ricky
Default Question About NXT
There are 2 versions, the first is the under layer which is suppose to be the main one, and the other is the booster.
When you guys say it's amazing, are you talking about the bottle version or the spray nozzle one which is the booster?
I've only used the booster so far and it's pretty good, I'd give it 8.5 out of 10. As far as the actual under layer wax, haven't tried it yet but I will be this weekend.
Which ones are you guys using, the actual wax, or the booster spray bottle wax?
Old May 27, 2004 | 06:29 AM
JokerDev's Avatar
JokerDev
I use both--I use the thick every few months to put a good coat on, and use the booster in between (once a week) to keep the shine. You can do it this way, but if you are only going to do one, I would use the thicker liquid. The booster is meant as such, to boost the shine of the other wax
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
