California Duster?
Old Jun 5, 2004 | 09:30 PM
350Zum's Avatar
350Zum
Default California Duster?
I have a Super Black Z and it looks stunning just after a wash and detail, however you know how black is, after driving for a while, it gets "dusty". My Z stays in the garage ALL the time, and I only drive it for FUN, will using a California Duster to "touch it up" in between full details add to the swirl marks?
I do wax it often and just use it as a "touch up", the C.D. is brand new, and it doesn't make sense to wash the Z when it gets dusty.
Any Comments?
Old Jun 5, 2004 | 10:15 PM
Kevin Overall's Avatar
Kevin Overall
I have used them for years on my black vehicles and never had a problem, they are good for light dust but do not use them to replace wash jobs. They do however deposit a trace of oil from time to time which can easy be removed when you use your liquid detailer.
Old Jun 6, 2004 | 05:29 AM
JokerDev's Avatar
JokerDev
No problems here either...the trace oil is the wax and should only happen the first few times you use it.
Old Jun 6, 2004 | 06:05 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
It is coated in paraffin wax. If you wrap a new one in newspaper and change the newspaper every day for about a week, it won't make those wax marks quite so much.
I've had mine for about 8 years now and haven't had any wax marks for many years. It works great for dust but don't do it if the car is truly dirty.
Old Jun 6, 2004 | 07:44 AM
CelticPride2's Avatar
CelticPride2
I've had mine for about a year now, and I agree with everyone here...it's no substitute for a proper washing, but if you've got a SuperBlack with some light dust you want to knock out, it's the only way to go.
Old Jun 14, 2004 | 06:19 PM
Jetpilot718's Avatar
Jetpilot718
For superblack, I recommend using Meguires Quick Detailer to remove the layer of dust. This way, you arent removing the dust dry, you have a wet cushion in beween the cloth and the paint.
Old Jun 14, 2004 | 06:22 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Yes, but aren't you just rubbing in the dust with the spray on detailer? I would think you are at risk for swirls if your not really careful. I have never seen swirls with the duster since it actually lifts the dust off of the paint instead of rubbing it in.
Old Jun 14, 2004 | 11:56 PM
Beaker02's Avatar
Beaker02
Get a duster. You wont look back.
Old Jun 15, 2004 | 12:30 AM
s9am_me's Avatar
s9am_me
Doc, so the CA duster still performs well up to now?? is it all black and dirty looking?? the tag says the dirtier it gets, the better it works.. you find this to be true?
Old Jun 15, 2004 | 03:19 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Yep. It seems to pick up dust better and it no longer leaves the little parafin wax streak anymore.
Old Jun 22, 2004 | 06:28 PM
desiZ's Avatar
desiZ
i use the duster almost every nite (so dusty here in cali), but i've noticed on the 3rd or 4th nite after a wash, because of the road grime i'm guessing, there are streaks with the cali duster (not permanent ones, just light dust streaks).
i was going to get meguiar's quick detailer, but then i just read on a previous post that it contains silicons & also should not be used alongwith zaino.
then i thought Z6, but again read somewhere that Z6 is only for right after you wax the car.
so someone please recommend a quick way to get dust off without scratching ... not the hose the car & dry.. cause that's as good as washing the car all over again...
Old Jun 22, 2004 | 09:56 PM
mrZeee's Avatar
mrZeee
cali duster 1st...then quick detailer...I've used quick detailer even after rain storm and have had good luck...but then again I have a silverstone...which doesn't shine up purrty like superblack...but isn't half as hard to "pamper"
Old Jun 23, 2004 | 03:01 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
You can use Z-6 anytime, not just after waxing.
BUT, if you have driven your car all week and have "road grime" on it, it would be best to wash it before you do anything else. I wouldn't be dragging a duster over the paint for anything other than just DUST. You'll scratch it if you use a duster on DIRT.
Also, I wouldn't recommend just a quick detailer (like Z-6) on DIRT either. Again, scratches/swirls.
PLAYDIRTY
Oct 12, 2015 07:45 AM
Prinny
Southern California
Sep 28, 2015 08:43 PM
