water spots on windows
Old Jul 19, 2004 | 08:06 PM
z33saru's Avatar
z33saru
Default water spots on windows
hey guys,
when i washed my car, i left the windows for last, and i guess because of this, the water dried up and there were lots of water spots left behind.
i am unable to get ride of the spots, no matter how hard i scrub with a towel.
do u guys have any suggestions for me to get rid of these horrible water spots?
thanks in advance for your help
Old Jul 19, 2004 | 08:45 PM
AmyCroft's Avatar
AmyCroft
Default Re: water spots on windows
Originally posted by z33saru
hey guys,
Saru
Please double check me - but I recall someone post about
using Clay Bar on Windows - you need the keep bar wet with lubricant.. Afterwards a lot of windows cleaner to remove the wax/lubricant.
Cheers Amy -
Old Jul 19, 2004 | 09:20 PM
n8vz's Avatar
n8vz
Autoglym Glass Polish & Cleaner
http://www.properautocare.com/autglaspol.html
Old Jul 19, 2004 | 10:03 PM
z33saru's Avatar
z33saru
thanks so much for the help guys.
i will try those methods the next time i wash again, which will probably be in a few days, hehe.
Old Jul 20, 2004 | 04:21 PM
juanjox15's Avatar
juanjox15
Hey z33saru,
Try using the Mr. Clean Autodry. It haves filters that once you wash the car, you soak the car with the filtered water and no spots are left behind. You won't have to handdry your car either. Let me know how it works!
Old Jul 20, 2004 | 09:08 PM
Kevin Overall's Avatar
Kevin Overall
Simply rub your glass with white vinegar, the vinegar will dissovle the chemicals that caused the spotting, if that does not work try Zaino Z-12 Glass cleaner, it is an abrasive compound that will remove any spot from any glass...
Old Jul 21, 2004 | 09:17 PM
z33saru's Avatar
z33saru
i just tried the vinegar since it looked like the easiest solution.
i didnt have white vinegat, so i just used wut i had which was rice vinegar.
...and it worked great!
thanks all for your help.
Old Jul 21, 2004 | 09:21 PM
AmyCroft's Avatar
AmyCroft
Default Good Tip - Vinegar
Great I'll try that on my White 1981 Turbo Coupe.. Looks like it was parked in the sprinklers for years...
Cheers Amy -
ablaine
Nov 29, 2016 10:13 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
kyin
Oct 15, 2015 05:54 AM
