about removing Zaino
Old Aug 14, 2004 | 09:17 PM
entropy's Avatar
entropy
Default about removing Zaino
Hi I have applied 2 layers of Z5 and 3 layers of Z2 last month. Right now only did I realize I only had a few section of the car clayed (it was 5-months-old black Z back then) and I know you guys are going to say "paint prep is everything". So I am thinking about removing my Zaino and reclay the entire car. Making sure the paint is perfect.
The question is how do you remove it completely?
thanks a lot
Old Aug 15, 2004 | 06:03 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Sal says Dawn and clay don't remove Zaino and I know that I have clayed the car (not with Dawn however) and it didn't remove my Zaino.
You may try washing with Dawn and then claying the car with a lube solution of Dawn and water. This may be all that you need.
I have heard that applying alcohol (not the drinking kind) to the car removes Zaino. I have never done this however.
You can e-mail Sal and he will reply personally.
zainobros@zainobros.com
Old Aug 15, 2004 | 07:58 AM
HotRodGuy's Avatar
HotRodGuy
try a good paint prep like the one supplied from griots
Old Aug 15, 2004 | 02:37 PM
Kevin Overall's Avatar
Kevin Overall
You do not have to remove any Zaino at all, just clay the car as is and the clay will pull up and out any paint contamination that is present on the surface, kinda like a razor pulls up and cuts the beard on ones face and then re Zaino the areas you clayed.......
Denatured alcohol rub down is an easy way to remove Zaino or any durable wax or polish, or use 3M Wax and Grease remover....
Old Aug 15, 2004 | 03:41 PM
HotRodGuy's Avatar
HotRodGuy
so you are telling me that the clay is going to remove the contamination underneath the areas he already zaino'd?
Old Aug 16, 2004 | 08:20 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
There shouldn't BE any contamination underneath your Zaino if you did the proper paint prep.
Sal likens the way the clay pulls out bad stuff from the polymer to the way you pull out a splinter sticking out of your skin just a tiny bit.
Old Aug 16, 2004 | 08:36 PM
jun14scr's Avatar
jun14scr
well i zainoed a few days ago. let the final z2 coat dry over night. (used zfx) and tried to buff it off. but you could still see where i applied it. i said i'd just wash the car again to see if it went away. waashed my car. didnt go away. z6ed it. didnt go away. should i just apply another coat of z2 over it?
Old Aug 17, 2004 | 05:26 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Don't let it sit overnight if you use ZFX. You take it off right away with the ZFX. Try to buff it out again with the Z-6. You'll have to rub pretty hard to get rid of the streaks but they should come out.
If you want to let it sit overnight, don't use the ZFX.
Old Aug 17, 2004 | 10:42 PM
cquence 350 [Z]'s Avatar
cquence 350 [Z]
how much can I get a complete set of Zaino for?
Old Aug 18, 2004 | 11:36 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
go to http://www.zainostore.com and find out all of the kits they sell and at what price.
Old Aug 26, 2004 | 01:54 PM
Poison123's Avatar
Poison123
Google Bot
Bonz, I've found when i'm getting ready to clean off the polish after a waxing that using the Zaino Spray and something to wipe it off with does wonders for getting rid of any streaks that are left behind.
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
