Can Z-5 be put on with the PC 7424?
Old Aug 31, 2004 | 12:21 PM
goldndwgz's Avatar
goldndwgz
Default Can Z-5 be put on with the PC 7424?
Not sure if this has been covered but.....i did a search and 800+ pages came up so i was hoping someone could give me an answer...if it can be used what setting should the machine be on....i have a SB and your typical spiderweb and fine scratches...help....
Old Aug 31, 2004 | 01:37 PM
manofsteele2003's Avatar
manofsteele2003
It has been covered before and the thought was that it just waists Zaino. Besides the Z-5 doesn't buff out the scratches, it just fills them in.
Old Aug 31, 2004 | 03:53 PM
Kevin V's Avatar
Kevin V
Using a buffer with Zaino is a waste.
Old Sep 1, 2004 | 05:02 PM
KShep's Avatar
KShep
+1...Zaino should be applied to paint in a very thin layer, which I would find difficult to achieve with a PC. In additon, it's best to apply the product with back and forth/straight line motions. It comes off so easily I don't see that you would need the PC for that either.
It depends in large part on how experienced you are with the orbital...they are great for applying polishes that REMOVE paint imperfections or for buffing out waxes. I only use the PC on my truck...I'm not that accomplished with it and afraid of doing more harm than good.
Old Sep 2, 2004 | 09:51 AM
HotRodGuy's Avatar
HotRodGuy
I have done it before w/ great results. A little goes a long way still but you use about 2x's as much product, the foam pad sucks up a good amount.
Personally, I prefer putting on my final steps (wax's/sealents, etc) w/ the PC and a finishing pad if I have it laying around and already out. I feel the PC helps ensure you get full coverage. I'll also occasionally use an MF bonnet over a clean pad to remove product.
If it's a waste w/ zaino then it's also a waste w/ almost every other product out there. It's just saves the man work at the cost of wasting some product.
One product I do think is pointless to apply w/ the PC is p21s/s100 as you put on and wipe off immediately and are only doing a panel at a time.
Old Sep 2, 2004 | 10:03 AM
HotRodGuy's Avatar
HotRodGuy
found a good write up on Autopia
http://www.autopia.org/forums/showth...ino+by+machine
sherm
Apr 11, 2020 05:21 PM
kyin
Oct 15, 2015 05:54 AM
