New Car - swirls
Hi all,
I recently bought a new car w/minor swirls (damn dealer wash).
Here's the products I currenlty have:
PC orbital buffer
Mcguiars #26
3M Imperial Hand Glaze
Mcguiars Gold Class
Mcguiars QD
I've read a lot about removing swirls, but am not sure if I should go out and buy new products if what I have will work.
Although, I'm thinking about getting the 3M SMR. Will this be too harsh for a new car (born date 07/04). I've used the 3M IHG on a small portion and it does not appear to "hide" the swirls too well. Maybe I need two coats.
I plan on doing the following this weekend:
Wash w/dawn
3M IHG or 3M SMR
Mcguiars Gold Class 2x
Any advice on the 3M IHG vs. 3M SMR?
PS - I know about the other waxes/sealants (i.e.- Klasse, AOI, Zaino), but I just want a BASIC, easy 3 step process.
Thanks!!
PC orbital buffer
Mcguiars #26
Mcguiars Gold Class
Mcguiars QD
Wash w/dawn
3M IHG or 3M SMR
Thanks!!
if a glaze is not working..move up to next level of abbrasiveness (not sure what that is with 3M products).... and try topping with NXT instead of gold class..NXT has some swirls filling abilities as well..also I think the NXT combines attributes of gold glass and #26 into one step...
3M SMR
3M Glaze
NXT x2
again not too familair with 3m products...but like sanding go with most abbrasive 1st to least abbrasive then coat/seal
3M SMR
3M Glaze
NXT x2
SMR will simply fill the swirls. The PC with a polishing pad and 3M's FI2 (assuming you prefer 3M's polishes) would safely remove light scratches. Then you could use your IHG followed by 26 or skip right to 26. 2 coats (with about 24 hrs of curing time in between), will last you a few months. Pair it with Meg's QD for occasional boosts, and it helps to have the QD to mist the applicators before putting wax on them... I get more even application and waste much less product that way.
EDIT: make sure you clay first
I don't think I need to clay the whole car..maybe the roof and bumper.
I understand the SMR to be an abrasive also (and hear good things about it). I think I am going to buy it for this application.
Wash
SMR
IHG
#26 x2
So much for a simple three step process.... but it's worth it.
Any other comments are welcomed.
Wash
SMR
IHG
#26 x2
i've used scratchX on localized areas of my car and it didn't seem to do anything
seriously, swirl marks are annoying but when you think about it, all these swirl removers do is remove more and more of your clearcoat... which in the long run ends up being worse on your paint
imo - just live with it... if you wash and wax regularly, you won't notice the swirls since they'll be filled in and you're ADDING layers of protection to your car rather than stripping it away with an abrasive
Thanks for all the comments...
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
BobC-Z
Sep 18, 2015 01:57 PM
