Drag NHRA, IDRC, IHRA, NDRA
Weld Rims For 350 Z
Old Mar 28, 2005 | 02:18 PM
Z ELIMINATOR's Avatar
Z ELIMINATOR
Default Weld Rims For 350 Z
Does any body know the offset and part # for a weld rim for the 350 z? 15x9 rims. want to fit a 275/50/15 DR on them. Front rims 15 X 3.5. With (stock brakes on car).
Are there any other rims that will fit the Z with these tires?
Also what tires are you guys running.
Thanks
Old Mar 29, 2005 | 01:43 AM
nitrous350's Avatar
nitrous350
Me Too
Old Mar 29, 2005 | 04:53 AM
one3502nv's Avatar
one3502nv
Thanks
We use 15x8's with that tire size and has the best contact patch and height combo.. Trust me, I have done my research... Anyway, If you use a 15x8, you need a 5.5" backspace and the bolt pattern is 4.5 which is 5x 114.3..
If you want to go with a wider wheel, and decide to go with a 15x10, than you need a 6.5" backspace... I haven't seen anyone running a 9" wide weld, but if you did, than I would assume a 6" backspace would be perfect..
Old Mar 29, 2005 | 04:56 AM
one3502nv's Avatar
one3502nv
and I forgot about the fronts. We tried a set of 15x3.5's but couldn't get them to clear the brakes, even with a spacer... I am not sure of the offset or backspace though.. I will have to check, and I will let you know what works when we figure it out.
Old Mar 29, 2005 | 02:09 PM
Z ELIMINATOR
Do you use the same studs. What is a backspace? Can you tell me how to set this up. I have no knowldge of these things.
thanks.
Old Mar 29, 2005 | 03:31 PM
95snoozer's Avatar
95snoozer
its a 15x8
they dont make 9s they look like this mounted
www.sesamestreetracing.com/welded2.jpg
look on a local mustang site to get a good deal on a pair used same size and offset
AbrasiveRaysive
Sep 20, 2021 02:29 PM
ablaine
Nov 29, 2016 10:13 AM
Jambo016
Sep 16, 2016 01:08 PM
