Drag NHRA, IDRC, IHRA, NDRA
100 Octane?
Old Mar 30, 2005 | 05:39 PM
mbonanni1856's Avatar
mbonanni1856
Default 100 Octane?
Does anybody have experiences (good or bad) with 100 octane in the Z? I am considering running it tomorrow night at the drag strip.
Old Mar 30, 2005 | 05:51 PM
G3po's Avatar
G3po
Default 100 octane
If your NA , then it's a waste of money for you. Won't hurt anything , just won't buy you anything. Now if you are FI or NOS, you can tune to 100octane and pull less timing/and or add boost , both of which can add signifiant power with added safety.
Old Mar 30, 2005 | 06:12 PM
JamRWS6's Avatar
JamRWS6
No, if he does not have a tune in the car to utilize a higher octane then it is useless. All higher octane gas does is prevent detonation.....whether that be from boost, hot spots, too much timing. It doesn't matter whether the car is NA or FI.
If he is on the stock computer tuning and not detonating then it is just wasting money.
Old Mar 31, 2005 | 08:17 AM
95snoozer's Avatar
95snoozer
waste of money unleess you are gonna run more timing
Old Mar 31, 2005 | 01:38 PM
barthelb's Avatar
barthelb
Master
When I did my upgrades, they had my motor apart and were looking at the pistons. Usually they said there is a lil carbon on the piston head from normal wear. They think the way I drive and the fact that I always put in 100 oct and mix it with 91 for a 94-95 mix that it kept them clean and shiny.
Old Mar 31, 2005 | 01:51 PM
G3po's Avatar
G3po
Default octane
Let me rephrase this, sure with a re-tune specifically for 100octane you can get some benefit , particulary with a more aggressive timing strategy; however, it hardly seems worth the cost given the small improvement, especially given that 100o ctane is not available everywhere at the pump.
Old Mar 31, 2005 | 01:52 PM
G3po's Avatar
G3po
Default octane
From what I've heard you drive the car pretty hard , and that alone will generally keep the carbon blown out.
Old Mar 31, 2005 | 02:40 PM
barthelb's Avatar
barthelb
Master
I wonder if carbon build up is needed or if a clean piston surface is what is preferred?
Old Apr 1, 2005 | 04:36 AM
95snoozer's Avatar
95snoozer
clean
carbon can stay hot and create embers which can cause premature detonation
running efficient can/will help you stay clean. aka not running pig rich.
nitrous has a way of cleaning it out too
Old Apr 1, 2005 | 06:08 AM
rednezz's Avatar
rednezz
For me it helps when its really hot outside because my car always seems to be on the edge of detonation. I only notice the improvement when I am at full throttle from 4500 rpms to redline.
Old Apr 1, 2005 | 07:00 PM
Ztrackman's Avatar
Ztrackman
I put in a tank of 100 octane a few weeks ago, just to check it out. My expectations about incremental power were very low. Gotta say I was surprised. In "normal" moderate driving it made no difference. However, with WOT high rev mode, it made a difference I could definitely feel. It felt like the cams really took advantage of the higher octane. Could be the usual Cali premium gas is crap at 91 octane.
Old Apr 4, 2005 | 07:54 AM
G3po's Avatar
G3po
Default octane
Yeh , it's the crappy 91. You'd see most of the improvement NA (witout reflash) going with 93 if avalable. The OEM program definately de-times on 91.
For those with 93/94 , the jump to 100 would yeild much less.
Old Apr 4, 2005 | 08:40 AM
mbonanni1856
Oh well, Nevada also has crappy 91 octane. So would 100 actually yeild some improvements for me?
Old Apr 4, 2005 | 11:34 AM
G3po's Avatar
G3po
Default octane
Some maybe, but if you can get 93/94 it will get you more bang for the buck.
The OEM ECU is not programmed to fully take "timing" advantage of 100 octane.
Old Apr 13, 2005 | 10:16 AM
webcarconnection's Avatar
webcarconnection
Well I can tell you what was my expirience... on N/A I put 100 oct. gas and the car put 8 whp more on the dynojet (same day, just minute in between) and race my brother Z to see if there was any difference and my car run much better than before... my mods at that time, Exhaust, intake, plenum, pully, cat pipes and headers.
oh btw my brother did the same thing afterwords and make the same results!
Old Apr 13, 2005 | 12:12 PM
mbonanni1856
Thank you, I will try it then. Finally some cold hard proven numbers. I have the same mods with the exception of headers. By the way, is your premium gas 91 or 93 octane where you are?
Old Apr 14, 2005 | 07:38 AM
webcarconnection
93 oct. we are in Puerto Rico very hot temp. here
Old Apr 14, 2005 | 08:09 AM
mbonanni1856
Ok, well we have 91 octane here in Vegas where it also gets very hot, so it may even yeild more results for me.
Old May 11, 2005 | 07:25 PM
Dave B's Avatar
Dave B
Sport Compact Car picked up about 6whp by using 100 octane vs running 91 octane on their project 350Z. The gain was mostly realized from 5000-6600rpms.
Old May 11, 2005 | 09:25 PM
DomZ's Avatar
DomZ
Guys, 100+ octane works, in moderation. Try a 3:1 93:103 octane mixture...the ECU starts to realize how the fuel is burning and feeds you more power gradually.
sales@czp
Sep 23, 2019 03:30 PM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
Mattg350z
Oct 2, 2015 06:51 AM
SharX59
Sep 27, 2015 09:23 AM
