Drag NHRA, IDRC, IHRA, NDRA
shift point in manual mode
Old Apr 19, 2005 | 08:35 AM
bigo109's Avatar
bigo109
Default shift point in manual mode
i just started using manual mode when i race. i have the ts flash so my rev limit is 7000rpm's. anyway 6250 rpm's seems to be the best shift point in the manual mode because the tach continues to go up even after you shift. does anyone else have some advice shifting in manuel mode?
Old Apr 19, 2005 | 12:27 PM
BluZee's Avatar
BluZee
I still have the stock rev limiter so I just make sure it shifts right before it hits. Around 6200 sounds right, because like you said, theres a little delay before it actually shifts.
Old Apr 19, 2005 | 05:52 PM
JonsilvZ's Avatar
JonsilvZ
I shift at 6400rpm. The cutoff is around 6800. Have to get close to the limiter. So going into the next gear will be over 5k rpm.
Old Apr 19, 2005 | 06:04 PM
bigo109's Avatar
bigo109
thanks for the info guys! good luck racing this year!
sherm
Apr 11, 2020 05:21 PM
