Drag NHRA, IDRC, IHRA, NDRA
First time in 2 hours! Help!
Old May 3, 2005 | 10:09 AM
DomZ's Avatar
DomZ
Default First time in 2 hours! Help!
Ok, so I have a 03 5AT with the stock tires and I'm going to the track for the first time EVER today...What PSI should my rears be at? Any tips for getting the Potenza's to hook? What should I be stalling it to?
Old May 3, 2005 | 10:12 AM
tacomaboy's Avatar
tacomaboy
1/4 mile track I assume?
I run my rears at 26... best time of 13.93 so far...
Old May 3, 2005 | 10:17 AM
DomZ's Avatar
DomZ
26 sounds good, I'll take care of that. I have my TS instructions with me to reset the ECU between runs if I run a crappy time, would that help?
Old May 3, 2005 | 10:19 AM
tacomaboy's Avatar
tacomaboy
AFAIK only if you are having hesitation or something... if you have other mods (even intake) you may want to do that, and check the results.
Also, you probably know, but just in case, run the fronts at 35+psi. TCS OFF.
Launching is a *****.
and HAVE FUN!
Old May 3, 2005 | 10:22 AM
DomZ's Avatar
DomZ
Heh, that'd be a sight with TCS on, you'd see my tires squeel for a sec, bog until about 4, then bog again at like 6....
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
