Drag NHRA, IDRC, IHRA, NDRA
What fuse to pull ??
Old Jun 13, 2005 | 11:47 AM
Way Slow Z's Avatar
Way Slow Z
Default What fuse to pull ??
What fuse are people talking about pulling out before going to the track ??
Any quick free mods to help e.t.s before going to the track ??
Went Fri car ran 9.21 1/8 and 14.42 1/4 its all stock I'd like to get in the 8's with out putting any $$ mods on it yet ....
Old Jun 13, 2005 | 02:06 PM
DayBlueZ's Avatar
DayBlueZ
https://my350z.com/forum/2003-2009-nissan-350z/127170-where-is.html
Old Jun 13, 2005 | 02:15 PM
Way Slow Z's Avatar
Way Slow Z
Thanks ... Im hoping I can launch harder by removing this.. it seems dead the first 10ft it moves .....
Old Jun 14, 2005 | 06:22 AM
Way Slow Z's Avatar
Way Slow Z
typo on 1st post went 14.25 ... Can you not edit your posts here ?
Old Jun 15, 2005 | 04:36 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Are you at high altitude? If your on street tires you dont need to pull your fuse. If you want to heat up slicks or DR's then you could pull it, or just do a 2nd gear burnout. And if your Z is not moving the first 10 feet, launch harder! Are you turning off your TC?
Old Jun 15, 2005 | 04:56 AM
Way Slow Z's Avatar
Way Slow Z
DA when I ran was 3600 ft but alt is not that high 400-600 ft
Mostly want to get it to leave at a higher rpm .. I turn stage light on and put it to the floor it only goes 2400 or so then let go of the brake. Is this part of the computer or is the converter that tight ?
Old Jun 15, 2005 | 07:24 AM
Alberto's Avatar
Alberto
Cranky FI Owner
You have an auto?
Old Jun 16, 2005 | 05:15 AM
Way Slow Z's Avatar
Way Slow Z
Originally Posted by Alberto
You have an auto?
yea its a auto
Old Jun 16, 2005 | 11:52 AM
fowlman01's Avatar
fowlman01
yea its a auto
I have an 5AT and I can sit in the water pit at the drags and bounce off the rev limiter all night if I wanted to. It has absolutly no effect on my car. I have never taken the fuse out.
Best time so far is 13.903. I did about five 14.0's last night.
I am using Micehlin PS tires and they hook up better when heated.
Old Jun 17, 2005 | 02:53 AM
Way Slow Z's Avatar
Way Slow Z
Hmmm it will just barley spin the tires ... like I said it wont go past 3000 rpms unless your not using the brakes .. We goin to the track tonight so I'll post some times when we get back.
Old Jun 17, 2005 | 07:28 AM
DayBlueZ's Avatar
DayBlueZ
Good luck with it. I'm heading to the track also. First time since i installed the mods.
Old Jun 19, 2005 | 07:11 AM
Way Slow Z's Avatar
Way Slow Z
It worked went a 9.13 1/8 mi now the prob is it spins pretty bad and you have to be easy when leaving ...now need some nittos
sherm
Apr 11, 2020 05:21 PM
Fixxxercask
Nov 9, 2015 11:10 AM
kyin
Oct 15, 2015 05:54 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
