Drag NHRA, IDRC, IHRA, NDRA
Questions
Old Jun 22, 2005 | 10:24 AM
FRIT-Z's Avatar
FRIT-Z
Default Questions
First time ever this weekend...I have been reading here but I have a few questions.
See my signature below for existing mods...I'm hoping I can run high 13's at a little over 100 mph.
Will I have to shift to 5th gear near the end or just push 4th real hard?
Should I take out spare tire and run on a 1/4 tank or less of gas.
How about octane boosters?
Tire pressure...I was going to try 30 psi first, then maybe lower a little.
Any advice would be appreciated.
Thanks,
Fritz
Old Jun 22, 2005 | 10:26 AM
FRIT-Z's Avatar
FRIT-Z
also...new mods
nismo rtune flywheel
nismo rtune clutch
Old Jun 22, 2005 | 10:49 AM
mrtomcat's Avatar
mrtomcat
Thanks,
Fritz
you might have to hit 5th right at the end, I don't have to but I have my limiter raised to 7100rpm.
the lighther the car the faster you can be....weight reduction buys a lot
octane booster does not buy you anything unless your FI
stock tire pressure should be at 26 psi (rear only)
launch around 2500 rpm, slip the clutch just a bit.
Have fun, be safe, first sign of traction loss get off the throttle.
hope this helps a bit
Old Jun 22, 2005 | 10:51 AM
DomZ's Avatar
DomZ
Woah buddy, run at Atco, you'll do a hell of a lot better than high 13's at 100mph. I did mid 13's @101 and 102 all day at Atco STOCK.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
