I run the ET Streets at 14 psi with a good 5 second burn out using my line locks
ok thanks, my line locks are sitting on my table, havent had a minute to install them yet, 9 psi was scary as hell at 100 mph, i felt like i was going to hit the wall with all the swaying back and forth...
thanks again, whats your best 60 times with slicks??
what is the thread pitch on the lug nuts???? 1.25? is that the same as the ones on the mustangs? i have a set of prostars at home with et streets mounted but i don't want to use the lug nuts that i have which came off a 04 stang. unless it is the right size then i will torque them down, otherwise i might strip it and f everything up.
