Drag NHRA, IDRC, IHRA, NDRA
Does 15x10 welds w/ 4.5 bs fit the Z?
Old Oct 1, 2005 | 10:53 AM
dlt1cy's Avatar
dlt1cy
Default Does 15x10 welds w/ 4.5 bs fit the Z?
I don't have the brembos, but will they fit?
Old Oct 3, 2005 | 11:54 AM
mjedens's Avatar
mjedens
They wouldn't work on mine! I had to go with the 15 by 8's!
Old Oct 3, 2005 | 12:45 PM
mrtomcat's Avatar
mrtomcat
here the ones that most of us are using:
927-96-58210 (Jegs.com)
Pro Star 96-Series Wheel
Size: 15'' x 8''
Bolt Circle: 5 x 4-1/2''
Rear Spacing: 5-1/2''
$159.99
Old Oct 3, 2005 | 12:46 PM
mrtomcat's Avatar
mrtomcat
why would 10's not fit????
Old Oct 3, 2005 | 02:32 PM
dlt1cy's Avatar
dlt1cy
mjedens, i know you said they wouldn't fit, but i wasn't sure if that was the same backspacing. i saw some on SCF for sale, so i had to make sure. so 15x10s wont fit no matter what?
Old Oct 6, 2005 | 11:54 AM
raptorbh12's Avatar
raptorbh12
i have 15x8's and they fit fine now...
I hade to use a half inch wheel spacer but otherwise they are great for the strip.
Note : i dont have brembos
Old Oct 6, 2005 | 02:16 PM
dlt1cy's Avatar
dlt1cy
raptorbh12, what is the backspacing on those 15x8? i am just curious why the need for the spacer on that size?
Old Oct 6, 2005 | 06:08 PM
raptorbh12's Avatar
raptorbh12
haha no clue what the bs is on my wheels, im just glad i got them to fit on my car.
Old Oct 7, 2005 | 10:10 AM
mrtomcat's Avatar
mrtomcat
the 15x8 do not need backspacers if you use the model I listed on the top of the thread
Old Oct 10, 2005 | 09:34 AM
one3502nv's Avatar
one3502nv
in a 15x8, you need a 5.5" BS... In a 15x10, you need a 6.5BS.. the 4.5" BS WILL NOT FIT... Hope this helps...
Old Oct 13, 2005 | 11:15 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Yea...tell me about it...I learned the hard way. Had to send wheels back. :P
Old Oct 13, 2005 | 01:06 PM
Badmonkey's Avatar
Badmonkey
What is the widest tire that can fit on the Weld 15x10 with 6.5" BS? Is 12.5" too wide?
Old Oct 13, 2005 | 01:20 PM
mrtomcat's Avatar
mrtomcat
Once again: great choice for your quote of the week!!!
Old Oct 13, 2005 | 02:17 PM
one3502nv's Avatar
one3502nv
The question is not what is the widest tire for the wheel... But should be what is the widest for the Z.. :-) On the 10" wheel, you should be able to sqeeze a 12" tire but you really don't need anything that wide... I am running a 10.5 wide tire on a 8" weld.. You should run a 26 or 27 x 11.5 on the 10" if you want... Your problem won't be traction, it will be with your drivetrain... I already have too much traction w a 10.5 tire and 450 whp.. But if your pushing more than that and upgrading yours axles n drivetrain, then i would go w a 11.5 maybe.....
Old Oct 13, 2005 | 03:12 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I really like it too Only problem is I found another gem of a quote, but I don't want to take this one down...boo...
Old Oct 15, 2005 | 05:52 AM
dlt1cy's Avatar
dlt1cy
Thanks guys! I forgot about the width of the tire.
Old Oct 16, 2005 | 12:25 PM
AL R.'s Avatar
AL R.
Quick ?
Would a 15 x 8 wheel with a 5" bs fit.
Checkout centerline wheels, telstar- name of wheel.
I have these on my mustang right now with a 275/50/15 bfg dr's
I''m just throwing out another possible option for you guys.
later
AL
Old Oct 16, 2005 | 01:44 PM
Badmonkey's Avatar
Badmonkey
A 5" BS on an 8" whell, equates to a +12 offset. I think this would work, as I have a +20 offset on a 9.5" wheel, now.
Old Oct 19, 2005 | 02:59 PM
bio911's Avatar
bio911
what size lug nuts???
Old Nov 3, 2005 | 11:01 AM
JERZ33's Avatar
JERZ33
Ordering WELD Drag Lights 15 x 8 4.5BS, Mickey Thompson 26.0/8.5-15 ET Drags.
Too much traction for a stock car?
