Drag NHRA, IDRC, IHRA, NDRA
Anyone know from experience?
Old Oct 19, 2005 | 06:25 AM
350NISMO's Avatar
350NISMO
Default Anyone know from experience?
Hey guys, is having a full tank of gas vs. empty tank going to be the difference between 13s and 14s?
Old Oct 19, 2005 | 06:53 AM
95snoozer's Avatar
95snoozer
hell yes it will effect your trap speed
how many gallons is your tank?
* 1 gallon of water equals 8.33 lbs.
* 1 gallon of gasoline equals 5.8 to 6.5 lbs.
* 1 gallon of ethanol equals 6.59 lbs.
i used to run with less than an 1/8th at the track and cary a 3 gallon gas can with me for when i ran out and it was time to go home.
last time at the track, i said screw it and ran with a half tank. the extra weight had .5-1 mph effect on traps, but i was rewarded with more traction than usual and a new best 60'
so its up to you
do you have your jack and spare tire in? that should come out and run 1/8th a tank at the track, 1/4 if you plan on making lots of passes
if traction suddenly worsesns due to the lighter rear, which it shouldnt... yall have IRS I assume.... toss the spare and jack back in.
also drain the windshield wiper sprayer tank in the front, could be worth 10 pounds off the front of the car and helps in weight transfer.
Old Oct 19, 2005 | 09:15 AM
raptorbh12's Avatar
raptorbh12
yea i always run with fuel light on, it makes a huge difference, one that i can notice just driving on the street when im empty.
Old Oct 19, 2005 | 09:24 AM
jackie chan's Avatar
jackie chan
with the fuel light on, a z has about 4-5 gallons left in the tank. the only problem is you don't want to run the tank so low on fuel you starve the pump from fuel being pulled away racing
Old Oct 19, 2005 | 08:05 PM
350NISMO's Avatar
350NISMO
Default New times PR
Ran the quarter at Gville Raceway
Best Quarter Mile Time 13.879@101.56 with 2.208 60'
Best Trap Speed 13.994@102.27 with 2.197 60'
Click here for slips
Old Oct 20, 2005 | 10:35 AM
The different is about 0.1 seconds/100 pounds. That is a rough estimate.
Old Oct 20, 2005 | 10:50 AM
barthelb's Avatar
barthelb
Master
I always run with 1/2 tank, my spare and about 20lbs of bullsh1t in my car. I'll go light weight next time at the track and see what happens. I'll go 1/4 or less of gas and no spare or crap in the car. Hell i might even take out some floor mats.
Old Oct 20, 2005 | 11:31 AM
crab daddy's Avatar
crab daddy
I normally remove my spare and tool box... I used to run with around 3-4 gallons of gas but i ran into issues of the fuel getting pushed to the back of the tank and making the gas guage go down to below E on a hard launch... since it made me nervous that i was going to go lean and pop a piston for a little weight savings... for saftey reasons i now run on a half tank
it wasnt really an issue until i started running mid 12s
Old Oct 25, 2005 | 03:19 PM
95snoozer's Avatar
95snoozer
great,
might think about grabbing a set of nittos to get your 60s down below 2.0
you will see 13.3s-13.5s then
trust me, way more satisfying modification than buying a coldair and adding more power and only running a tenth faster with more mph
416blueZ
Jun 11, 2024 10:56 AM
Workshop12
Mar 23, 2020 01:45 PM
Juztin
Nov 22, 2015 07:03 AM
dcains
Nov 11, 2015 11:36 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
