Also, depending on your altitude and such times may vary. I happened to run at one of the closest to sea level tracks with some pretty good air so I managed a 13.6 stock.
This is very true. I was lucky to run a 14.9 stock at my track which is above 3000ft. Best Ive run modded is 14.3 with a best 60ft of 2.0. I usually get a 2.1.
Power brake. Put one foot on the throttle and the other on the brake to to pick-up rpm. The stock automatic will not give you 100 percent of the engines power with this circuit in place. Its a safety feature.
With all the mods that you have, this may already have been done.
