Drag NHRA, IDRC, IHRA, NDRA
Drag Race Shift Points?
Old May 27, 2006 | 05:23 PM
CarlosZ's Avatar
CarlosZ
Default Drag Race Shift Points?
I've had no luck with my 5AT. 15.01 best time at LACR in Pamdale. I had a pop charger and that was it. I have some test pipes and 19's now and need to know what is the best RPM to launch from, and at what RPM I should shift at for each gear in order to not over rev the motor past an effective rpm level. (I've heard that going to the redline is not always most effective due to the powerband.) Anyways I love the car but am rather sad with the performance. Any feedback would be welcomed. Thanks!
Old May 27, 2006 | 05:34 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i will tell you my best method with my old G sedan 5AT. i never tried to powerbrake the launch at all. i would just hold my foot on the brake and then floor it letting off the brake as soon as my foot hit the pedal. i ran 14.2s all day bone stock. not one mod done to it.
many people have better luck trying to stall it as high as possible.
i had a 04 and always left it in manu mode and could put it in third gear before i started off. this would automatically shift from 1st to 2nd and 2nd to 3rd then it would hold third till i shifted it. i would almost peg the rev limiter in 3rd and shift to 4th
i ran countless 12s with a 100 shot of nitrous on the basically stock sedan....
Old May 27, 2006 | 05:54 PM
Fairlady_z33's Avatar
Fairlady_z33
I have an 04 TT what I always try to do is not to spin the tires not even one bit. Shift points take it all the way to 6900 I think and shift you should do way better.
Now taking out you car since you have 19's I doubt that you get wheel spin so just power brake the car to 1800 I think it allows you too and stomp the hell out of the gas pedal. You should have a nice 0-60. BTW always try to heat up the tires just a bit so every run counts.
Old May 27, 2006 | 06:27 PM
mrtomcat's Avatar
mrtomcat
First of all LACR is way slow, badly prepped track and very high elevation. You won't do better there than 14.8 with your mods if at all.
Invest in some dr's
Shift 200 rpm before the limiter kicks in.....however I am confused didn't you say you have an automatic?
Old May 29, 2006 | 12:31 AM
CarlosZ's Avatar
CarlosZ
Yes I have an auto.
Old May 29, 2006 | 12:54 AM
gimpster621's Avatar
gimpster621
yea lacr sucks. 15 flat isnt too bad there for a stock 5at
Old May 29, 2006 | 12:57 AM
Mellowman's Avatar
Mellowman
I have found that when draging an auto that using the tiptronic mode to shift is slower than just letting the car shift automatically. You always have the option of torque braking.
Old May 29, 2006 | 09:44 PM
fowlman01's Avatar
fowlman01
I don't find it that way at all. In my car the manual mode is much faster.
Old May 29, 2006 | 09:48 PM
phatz33's Avatar
phatz33
+1
Old May 29, 2006 | 10:39 PM
CarlosZ's Avatar
CarlosZ
Thanks, I'll give it a try and I found out I can also take the brake fuse out to perhaps get a better launch. I'll keep you posted.
Old May 30, 2006 | 08:15 PM
bigo109's Avatar
bigo109
CarlosZ I would recommend you add a plenum spacer,exhaust and dr's in the near future. My car really came to life after adding the spacer and hi-flo cats. The 5at's seem to really like more air. Anyway try these tips first and then adjust them to suit your car.Let your car cool down for at least an hour before racing.Remove stop lamp fuse(for torque braking),turn tcs off, 1/4 tank gas left in car and remove spare tire,tools,etc. Since you're on street tires air down the rear tires to 25 psi. No big burnouts, just a small spin of the tires will do to clean off the tires. Brake launch at 2250 rpm's, manual mode shift at 6500 rpm's in each gear. Good luck!
EnjukuRacing
Sep 30, 2015 06:55 AM
