Drag NHRA, IDRC, IHRA, NDRA
Anyone break axles with drag radials on a 5AT?
Old Jun 5, 2006 | 09:59 AM
BluZee's Avatar
BluZee
Default Anyone break axles with drag radials on a 5AT?
I dont think it would be anything to worry about. Just wondering if there is any chance to break anything on a 5AT using drag radials? (just bolt ons)
Old Jun 5, 2006 | 10:08 AM
InjectedPerf's Avatar
InjectedPerf
Injected Performance
Most likely no. With the automatic the drivetrain is already preloaded so there is no shock to the system like the 6 speed manual cars have.
Old Jun 5, 2006 | 10:18 AM
BluZee's Avatar
BluZee
Thats what I thought. Just wanted to make sure.
Old Jun 5, 2006 | 10:41 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Ive never heard of a 5AT breaking an axle/cv joint-you'll be good to go...
Old Jun 5, 2006 | 10:58 AM
BluZee's Avatar
BluZee
Ill see how these work.
Old Jun 5, 2006 | 11:19 AM
InjectedPerf
With the automatic and basic bolt ons, are you spinning that much?
Old Jun 5, 2006 | 11:35 AM
BluZee's Avatar
BluZee
It not spinning that much but bad enough to hurt my time. Last time out I was spinning off the line and running a few tenths slower but with the same trap speed.
My mods are:
Popcharger
MD 5/16" Iso-T plenum spacer
KJR 2lb crank pulley
Injen SES exhaust
3.5 final drive
Old Jun 5, 2006 | 04:57 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
if you dont have a big stall and mods done to launch at a higher rpm. there is no need for more traction. you should pull 1.9s with your setup on decent tires. those tires are going to bog you down for sure without a stall....
Old Jun 5, 2006 | 06:49 PM
BluZee's Avatar
BluZee
Looks like we're going to find out. Thanks for the input. Maybe thats my next mod then.
Old Jun 5, 2006 | 07:00 PM
jackie chan's Avatar
jackie chan
keep them aired up and they will work great, they will definitely take the track prep variable out of a stock auto and allow you to flash your stock converter or stall it up. try both to see what nets you the best 60( i would flash it). they wont hurt you at all if the run out doesnt mess up your gearing
Old Jun 5, 2006 | 07:17 PM
BluZee's Avatar
BluZee
Yeah, I was going to start at 20-25 psi to start and see how it goes. Thanks. I usually just stall it up all the way. That seems to work better than flashing it.
Old Jun 5, 2006 | 07:22 PM
Audible Mayhem
My350z
maybe keeping it in neutral and revving it to 6000, then slamming it into driver will work wonders, i really dont know anyone that has tried it, i had a rental car that it worked GREAT on at stoplights...
Old Jun 5, 2006 | 07:33 PM
BluZee's Avatar
BluZee
Who said anything about doing that?
Old Jun 5, 2006 | 09:03 PM
bigo109's Avatar
bigo109
when I installed my nitto's last year, all they done was bog at low psi. 36 psi all around works for me. Launch at 2500rpm's and shift at redline and you'll be fine. Also let the car cool down for at least an hour before you race. Good luck!
Old Jun 6, 2006 | 04:45 AM
jackie chan
most aluminum headed motors that are tuned correctly run better when at temp. and i dont recommend the neutral drop
Old Jun 6, 2006 | 05:30 AM
BluZee's Avatar
BluZee
My car runs very consistent even after running a few times back to back. Especially after I installed the MD Iso Thermal set up.
Old Jun 6, 2006 | 06:15 AM
fowlman01's Avatar
fowlman01
I don't have the MD thermal part, but a friend does and it cools down very quickly. I don't think you will bog with DR's. I have only run them once, but I was spinning them at launch. They are BFG T/A G-Force DR's though. Different tread pattern than yours, but pretty sticky.
Old Jun 6, 2006 | 06:59 AM
If there is a way to destroy a axle, believe me, someone has done it.
Old Jun 6, 2006 | 07:41 AM
jackie chan
if you break an axle on a stock stall and drs. they were defective from the factory or you had nasty wheel hop
Old Jun 6, 2006 | 01:47 PM
dlt1cy's Avatar
dlt1cy
Two questions,
What is flashing your converter, and
Why dont you use 18-24 psi?
