Drag NHRA, IDRC, IHRA, NDRA
Tried my drag radials. I dont get it.
Old Jul 4, 2006 | 08:31 AM
Ozzie@Hppracing's Avatar
Ozzie@Hppracing
Originally Posted by bmac03z
How high? On a 5000rpm stall will my car not move til 4500rpms or something
It will move. But that is a little much for the st. It really doesn't change it much until you put a load on it. I am going with a 3200 or 3400.
Old Jul 4, 2006 | 11:57 AM
97supratt's Avatar
97supratt
I totally agree, anywhere from 3200-3500 is perfect for these engines.
Old Jul 4, 2006 | 01:49 PM
BluZee's Avatar
BluZee
You don't need a 6 speed. Just get a better stall. We put better stall's in mustangs and vettes all day long. A mustang auto that runs14.0 with a good stall will run 13.6. I have a 350z auto and i am putting a 3200 or 3400 in it. That should be plenty to keep you in your powerband. Also your 60ft will drop.
Im sure that Id get a better stall before I traded for a new car anyways. Thanks for the input.
Old Jul 4, 2006 | 05:37 PM
Dave B's Avatar
Dave B
The factory stall is already pretty high on this car with it being 2700-3000rpms depending on if the car is in 1st or reverse. I'd think going with 3,200-3,400rpms wouldn't be much of a jump. The only problem is that to give this car the stall it needs, it will be a slug around town.
Old Jul 4, 2006 | 07:13 PM
Ozzie@Hppracing
[QUOTE=Dave B]The factory stall is already pretty high on this car with it being 2700-3000rpms depending on if the car is in 1st or reverse. I'd think going with 3,200-3,400rpms wouldn't be much of a jump. The only problem is that to give this car the stall it needs, it will be a slug around town.[/QUOTE
You adjust it to your power adder. A well set stall is completely different then the stock. The stock one drops between shifts way to much. What is also pretty cool from the after market stall convert. is if you add a power adder you can always get it adjusted to how much power you are making.
Old Jul 4, 2006 | 07:53 PM
sq40's Avatar
sq40
Where can one get a stall converter for the 5At?
Old Nov 8, 2006 | 03:21 PM
ZLadie2000's Avatar
ZLadie2000
Old Nov 8, 2006 | 05:42 PM
Nealoc187's Avatar
Nealoc187
Did you really just bump this four month old thread to say "+1" or is it my imagination?
Old Nov 8, 2006 | 06:59 PM
Alberto's Avatar
Alberto
Cranky FI Owner
He'd rather bump a question that has been asked/answered in other sections of the forums countless times and obviously not getting answered here than search his damn self
Old Nov 8, 2006 | 07:16 PM
Julian@MRC's Avatar
Julian@MRC
Ill bump it again just for giggles..
Old Nov 8, 2006 | 07:46 PM
Zendem's Avatar
Zendem
Bizzump
...was wondering in my head why such an old thread was bumped?
Old Nov 8, 2006 | 10:19 PM
mrtomcat's Avatar
mrtomcat
the recomended tire pressure for MT ET Street Radials is 12 -16 psi for your size tire. You had way too much pressure in those babies....and yeah, get a 6 speed
http://www.mickeythompsontires.com/tech.php?bulletin=s7
Old Nov 9, 2006 | 04:31 AM
95snoozer's Avatar
95snoozer
3500 would be nice. yes the car will move well before 3k on the street. part throttle it might sit at 2500 when you are leacing an intersection
Old Nov 9, 2006 | 04:53 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Pull the brake fuse and you can launch @ whatever you want.
Old Nov 9, 2006 | 07:14 AM
BluZee's Avatar
BluZee
Sorry, Im going to go ahead and say that makes no sense.
Old Nov 9, 2006 | 07:48 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
The engine will not go over 3k with the foot on the brake in gear. Take the brake fuse out and it doesn't think the brakes are being applied. That's why people make the brake fuse mod kits, that and burnouts.
Old Nov 9, 2006 | 07:59 AM
dlt1cy's Avatar
dlt1cy
Sure about that? I can run it to the rev limiter with foot on the brake. That's how you do the burnout. I am confused. You dont want to launch at 3000+ rpm with the wheels already spinning?
Old Nov 9, 2006 | 08:10 AM
  #38
BluZee's Avatar
BluZee
I leave the fuse in and do burnouts over 6000rpm. Leaving the fuse in just cuts some of the power but doesnt stop you from going all the way to redline.
Your Z looks good, btw.
Old Nov 9, 2006 | 08:24 AM
  #39
jackie chan's Avatar
jackie chan
next time at the track. flash it instead of stalling it up. see what happens. i bet it pulls low 1.9s
Old Nov 9, 2006 | 10:14 AM
  #40
ZU L8R's Avatar
ZU L8R
Viper Sellout
I'm not sure about the 6MT's but I know on my 5AT I couldn't hold the brake down and go over 3k and do burnouts..
