Drag NHRA, IDRC, IHRA, NDRA
Tried my drag radials. I dont get it.
Old Nov 9, 2006 | 10:17 AM
  #41
BluZee's Avatar
BluZee
Originally Posted by ZU L8R
I'm not sure about the 6MT's but I know on my 5AT I couldn't hold the brake down and go over 3k.
OK, you cant hold the brake down to launch the car above 2500. You can slightly let off the brake to do a burnout all the way up to the rev limiter.
Old Nov 10, 2006 | 06:19 AM
  #42
95snoozer's Avatar
95snoozer
people are so confused in this thread
we are talking about a power braking technique not how high the revs can go over all. You dont want tire spin at the line whil waiting for the tree.
try placing it in neutral, revving the motor so the brake pressure allows you to push the brake further in. Then while holding brake down, place in gear and stall the converter as high as possible.
Try this or a flash technique:
Stage very shallow, apply only enough brake to stop the car from moving. light turns grean drop brake and hit gas simultaneously.
Old Nov 10, 2006 | 02:54 PM
  #43
dlt1cy's Avatar
dlt1cy
I guess all I am saying is, even without the fuse, you can't rev to 4k rpm without the wheels spinning. So, with or without the fuse you cant launch above 2500-2800. The fuse only helps with the burnout to warm the tires.
(for an at5)
Old Nov 10, 2006 | 04:16 PM
  #44
mrtomcat's Avatar
mrtomcat
(for an at5)
why would dr's spin at 4000? I launch at 5500
Old Nov 10, 2006 | 06:40 PM
  #45
dlt1cy's Avatar
dlt1cy
Do you have a 5at?
Old Nov 10, 2006 | 10:06 PM
  #46
mrtomcat's Avatar
mrtomcat
Do you have a 5at?
nope I have a 6mt, but should tire spin not be the same?
Excuse my ignorance, I don't know much about automatics
07ZEKE
Aug 23, 2021 09:15 PM
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
