Drag NHRA, IDRC, IHRA, NDRA
Engine temp. guage
Old Sep 7, 2006 | 05:25 AM
Miko's Avatar
Miko
Default Engine temp. guage
When turning the car on, I notice the temp guage slowly starting to rise after a few minutes of idle/driving. The thing is, it never comes to the halfway mark (like I've seen in other vehicles); it stays a bit below the halfway mark, even when racing the car. Just wondering what it takes to heat up the engine, so I'm asking you guys who drag/track your car for hours: does it heat up a good amount?
Thanks
Old Sep 7, 2006 | 05:46 AM
k3silk's Avatar
k3silk
maybe air in the lines? check fluid levels
Old Sep 7, 2006 | 10:55 AM
Alberto's Avatar
Alberto
Cranky FI Owner
My needle never moved past what you said, NA or even FI at a 90 degree hot as ***** track day. I wouldnt worry....
Old Sep 7, 2006 | 11:10 AM
trey.hutcheson's Avatar
trey.hutcheson
I've observed my needle staying pegged almost exactly at the half-way mark, even when coolant temps ranged from 145 to 215. That thing's not very accurate.
Old Sep 7, 2006 | 01:15 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
the stock gauge sucks, it will read the same from 170-200... i have the utec numbers to prove it
mine sits right under halfway ALL the time, once you get over 200 it will start rising.
it takes about 3 minutes of easy driving for the car to warm up...
Old Sep 7, 2006 | 01:32 PM
jackie chan's Avatar
jackie chan
i have an autometer water temp guage. when i had both it and the factory hooked up, the autometer would change 30*, while the factory would stay in one spot.
when i first bought the cobra, it was all jacked up. the water temp guage would read in the 220 range and the factory would be well below half way. alot of factory guages in vehicles are dummy guages(on/off). although i do like the oil pressure guage in the z.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
SharX59
Sep 27, 2015 09:23 AM
