Drag NHRA, IDRC, IHRA, NDRA
Horrible 1/8th....MD 1/4 mile results
Old Oct 12, 2006 | 06:00 AM
GfortheCPE's Avatar
GfortheCPE
Default Horrible 1/8th....MD 1/4 mile results
Ok, so I have a 03 G 6MT coupe...but I figured I would post here at 350z.com too since more Zs might drag race.
Here is my post about doing before and after runs for the MD 5/16 spacer.
http://g35driver.com/forums/showthread.php?t=120687
The conclusion was my avg trap increased 1mph and my avg et dropped .05.
The ets sucking are the result of my extremely notchy 1-2 shift which I am scheduled to have looked at by a dealer next week, and my bad launches....best 60' of 2.21
My best trap corrected (high temp humidity and low pressure eek) was 99.82 which is decent I think.
However my 1/8ths suck!!! most are 9.6 at around 74....is it safe to assume I could drop .3 and add another 1-2 mph if my 1-2 shift wasn't so notchy and stuff?
Any comments and advice welcome!!
Old Oct 12, 2006 | 06:05 AM
Alberto's Avatar
Alberto
Cranky FI Owner
You need help on that launch and first 2 gear shifts (1/8). Go back after you get a new tranny and let us know how you do....also dont "correct" times/traps they arent very good comparisons IMO. Just claim what you actually ran.
How are you launching? Where are you shifting? Tire pressure?
Old Oct 12, 2006 | 06:07 AM
Lenny U's Avatar
Lenny U
Don't know if this applies to the G's, but in the Z's especially in the 2003's the transmission generally needs work due to knotchy shifts.
Old Oct 12, 2006 | 06:38 AM
GfortheCPE's Avatar
GfortheCPE
Im launching by holding at 2.2-2.5k, and coming out of clutch and slowly going down on gas.
I get spin for about 10-15 feet and then it runs from 4-6.5k through first. BTW the track is horrible in my opinion best any of my opponents got (and some had drag radials) was a 2.1.
I have about 27-28 lbs pressure in my rears.
I shift at 6.5k, my 2-3 and 3-4 shift are pretty good imo....im sure they could improve some but its really the 1-2 shift that is killing me I think.
I think the 03 Gs (like me) have the same problems as the Zs when it comes to the extreme notchyness....hopefully that will be remedied shortly.
I was doing AD corrections because the temperature was 80 humidity 70% and pressure was lower than usual......also by using the same correction factors for the before and after runs I could get more accurate results of the MD spacer....otherwise it wouldn't be possible to compare results.
Old Oct 12, 2006 | 10:55 AM
Would like to see the time slips.
Old Oct 12, 2006 | 01:57 PM
GfortheCPE's Avatar
GfortheCPE
times are at g35driver.com in the above link...but
here they are again
RT .077
60' 2.213
1/8 9.596
mph 74.14
1/4 14.728
mph 96.06
RT .109
60' 2.288
1/8 9.685
mph 73.90
1/4 14.83
mph 97.70
RT .199
60' 2.367
1/8 9.836
mph 74.30
1/4 14.94
mph 96.78
Temperature was 80
Humidity was 65%
pressure was 29.82
altitude was 152
DA = 1920'
Old Oct 12, 2006 | 03:56 PM
I think that is reasonable for a G35.
Old Oct 12, 2006 | 07:29 PM
GfortheCPE's Avatar
GfortheCPE
G 6MT coupes should run low 14s...a few people have even broken into 13.9 with either stock and excellent track conditions or with only a few mods (and hella launch!)
My corrected time of 14.41 @98.41 is decent...but i think I am losing 2 or 3 tenths do to my crappy launch and 1-2 shift....and ofcourse that 14.41 is adjusted becuase the AD was pretty high (1920). Anyway...when nov dec rolls around and I hopefully get a new tranny I should see noncorrected 14.2s 14.3s. Or at least that is what I am aiming for...
lapham3
Oct 7, 2022 03:15 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
kyin
Oct 15, 2015 05:54 AM
