Drag NHRA, IDRC, IHRA, NDRA
Top 25 1/4 Mile Times For ( TT, ST, SuperCharger, Nitrous, Bolt-ons, Stock )
Old Sep 26, 2009 | 01:45 PM
  #1941
03threefiftyz's Avatar
03threefiftyz
I should mention.........the temp was NOT 90 degrees. The temps was ~65 at the time of the run, but it was humid.
Old Sep 27, 2009 | 11:39 AM
  #1942
Pat Bateman's Avatar
Pat Bateman
What track did you run at?
Old Sep 27, 2009 | 12:39 PM
  #1943
03threefiftyz
Crapital .
Old Sep 27, 2009 | 05:01 PM
  #1944
denchan350gt's Avatar
denchan350gt
Crapital .
I saw that run I was there. Good job. I think you need to do your burnouts a little longer to warm up your DR's you barely smoke them. I'm going to try to make it there this friday. I showed up too late to race.
I liked the Max with the VQ in it and that crazy sounding Acura TL. I guess AJ had his granddad driving his Z.
Old Sep 27, 2009 | 05:11 PM
  #1945
03threefiftyz
I didn't even do a burn out on the last run.........the previous run the rim spum inside of the tire because the car sat for 2 hours and the temp dropped 15 degrees. I didn't think too check it until I was blocked in. It dropped from 15psi to 9psi. I was uber cautious on the next pass (with 16-17psi) just in case. You're right though.
Edit....It also hurt me because there wasn't enough heat in the tires to keep from spinning going into 2nd and 3rd (it even chirped 4th). It's fine though...........I know there is a lot left in the car with a good 60' and not lifting to shift.
Old Sep 27, 2009 | 05:32 PM
  #1946
denchan350gt
I think I checked out 3 of your runs you were getting faster with every run I left after your 13.3 run. I thought you were AJ at 1st but noticed your tailights were not tinted like his.
Do you pull the brake fuse? The other Zs were in the 14's.
Old Sep 27, 2009 | 05:45 PM
  #1947
03threefiftyz
I didn't.....I was still just trying to get a feel for the new components. There is lots of racing time and weather here now.............I will keep getting myself and the car dialed in and hope for 12's. I will pull the fuse next time now that I am comfortable with how the car launches with the stupid light OS single. The 2nd to last run......I think it was a 13.58 or something......the speedo was over 120 and tach never dropped below 6500rpm because the welds were spinning inside the MT's. It was a worrisome pass......the car had a nasty shudder when I got off the throttle and braked.
I was the quickest Z/G there by over a 1/2 second easy. It was a bit slick out there...........I guess because of the rain we got on Thursday. It washed a lot of the rubber and vht away from the previous weekend.
P.S. I only ran twice after 5:30 .
Old Sep 27, 2009 | 07:20 PM
  #1948
gerryg2153's Avatar
gerryg2153
First time at the drags for me on friday
got about 12 runs in with my fat little 08 ZR (w bolt ons)
and nearly a full tank of gas ( I didnt plan very well)
best was 13.912 @ 100.45 mph 60' @2.12 and just a tad quick on r/t
not bad for a first try . . .
Old Sep 27, 2009 | 07:31 PM
  #1949
03threefiftyz
Not bad for a first crack at it........what were the weather conditions like?
Old Sep 27, 2009 | 08:40 PM
  #1950
gerryg2153's Avatar
gerryg2153
it was fri nite drags, so probably 80 to start at 6pm and 70+ @ 10pm
Old Sep 27, 2009 | 09:13 PM
  #1951
03threefiftyz
Like I said.......good effort for the first time out. Number 22 on the bolt-on HR list.
Old Sep 27, 2009 | 10:01 PM
  #1952
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Sorry I haven't updated the list for so long. I finally found some time to update the lists.
Overall:
7. Hal@IP -(daily)---05 6spd -Tour --------------Built IP ST 10.855@138.94mph 1.918 60ft slicks
updated the above to:
3. Hal@IP -(daily)---05 6spd -Tour --------------Built IP ST _9.891@148.77mph 1.669 60ft slicks
25. 500HPZ ----------03 6spd -Base ----------------Greddy TT 11.838@118.60mph ????? 60ft DR's
was bumped to 26th and off the list thanks to:
23. SH Luciano ------03 6spd -Tour -------------------APS ST 11.802@120.97mph 1.823 60ft DR's
Single Turbo:
2. Hal@IP----- 05 Tour 6spd -(daily)----- (Built)IP ST 10.855@138.94mph 1.918 60ft Verified slicks
2. Hal@IP----- 05 Tour 6spd -(daily)----- (Built)IP ST _9.891@148.77mph 1.669 60ft Verified slicks
added:
6. SH Luciano -03 Tour 6spd ------------------- APS ST 11.802@120.97mph 1.823 60ft Verified DR's
Bolt-ons (DE):
11. 1cockyZ -------Built BLock - 03 Trac 6spd 13.297@108.14mph 2.175 60ft Street
8. 1cockyZ --------Built BLock - 03 Trac 6spd 13.206@106.93mph 2.020 60ft Street
25. bluezee ---------------------03 Perf 6spd 13.627@101.97mph 2.048 60ft DRs
12. 03threefiftyz ---------------03 Tour 6spd 13.328@105.66mph 1.970 60ft DRs
Supercharged:
2. tylerxfire --------------03 Tour 6spd ----Vortech 12.037@115.19mph 1.684 60ft Verified ET Str
2. tylerxfire --------------03 Tour 6spd ----Vortech 11.905@115.41mph 1.664 60ft Verified ET Str
Stock:
32. OrleanZ33 ----------------------03 Base 6spd 14.006@_98.57mph 2.145 60ft
added the above
If you don't see your times and you posted your times on this thread, then I suggest you go back and read the first post. Also, do NOT PM me and ask me to update the thread. I'm subscribed to it so I get notifications. I get enough PMs daily as it is.
Old Sep 27, 2009 | 10:06 PM
  #1953
03threefiftyz
Thanks for the updates Chris........appreciate your effort.
Old Sep 28, 2009 | 07:28 AM
  #1954
ajcool2's Avatar
ajcool2
Yeah man my granddad was driving. Im sure you could tell by him taking off on the second yellow light lol. He did pull a 1.9 60' though. I told him to try shifting but he wasnt comfortable with it so he left it in D. The gold max had the 3.5 in it and it was in safe mode because of 12 engine codes most of which have been taken care of. The car has a low 14 second run in it as it sits. Once its modded and tuned it should be able to do a mid 13. Plus I let my girl race it all night and she doesnt have much experience.
I did have the DR's with me but couldnt find you.
Old Oct 1, 2009 | 05:13 AM
  #1955
brady's Avatar
brady
After dumping $3.5k into my car I finally hit 12's... just.
1. Year and Model (trim) of car = 2008 Grand touring
2. Auto or 6spd = 6spd
3. If you were running Street tires, Drag Radials or Slicks = DR's (Hoosier R6's, road race tires)
4. What type of Turbo or SuperCharger kit you are running = N/A
5. What Shot of Nitrous = N/A
6. If your motor is Built or not. = not
Mods: Bolt-ons + tune (I assume a tune is considered a bolt-on?)
Thanks to APH for installing all the stuff.
That's good enough for me. Time to move on...
Last edited by brady; Oct 5, 2009 at 06:04 PM. Reason: Included car detailed information
Old Oct 1, 2009 | 05:38 AM
  #1956
brady's Avatar
brady
DA was -646
Old Oct 1, 2009 | 07:11 AM
  #1957
03threefiftyz
Mannn I am jealous of that DA, but hopefully by Nov we can get some of that here in the mid-atlantic. Your car is absolutely charging through the second 1/8th.
Old Oct 1, 2009 | 07:13 AM
  #1958
Alberto's Avatar
Alberto
Cranky FI Owner
You could have hit 12's with only DR's
Old Oct 1, 2009 | 07:21 AM
  #1959
03threefiftyz
With that kind of trap speed (and 300.5whp) you could go 12.7 on drag radials without breaking a sweat.
Old Oct 4, 2009 | 02:10 PM
  #1960
str8dum1's Avatar
str8dum1
1. Year and Model (trim) of car: 2003 G35c
2. Auto or 6spd: 6sp
3. If you were running Street tires, Drag Radials or Slicks: DR's
4. What type of Turbo or SuperCharger kit you are running: Vortech
5. What Shot of Nitrous: 0
6. If your motor is Built or not.: No
12.3603 @116.55 with a 1.9179 60'
8.0698 1/8th @ 91.48mph
That was my best run of 2 (still bogged a little off the line), busted axles on 3rd pass.
