Drag NHRA, IDRC, IHRA, NDRA
350Z Clutch Smoked
Old Apr 28, 2007 | 06:20 PM
ZROCKET's Avatar
ZROCKET
Unhappy 350Z Clutch Smoked
Was at Midnight Mayhem last night making some runs. On the third pass clutch did'nt release on 1-2 shift. It was stuck to floor, used the tip of my toe to bring pedal back up. Big time burnt clutch smell. Let the car sit for an hour or so to cool the clutch down, hoping I could drive it home. Made it home ok. Did some stoplight runs, clutch seems ok. Pulled it into garage could still smell it was burnt. What do you think caused the pedal not to release and stay stuck to the floor? I'm going to replace the whole clutch/flywheel/linkage system. It's not urgent as the car is not my daily driver. Oh, the car has 2700 miles on it.
Old Apr 28, 2007 | 06:30 PM
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
Slave cylinder is what they say is the problem:
https://my350z.com/forum/showthread....lutch+sticking
Old Apr 28, 2007 | 06:32 PM
plumpzz's Avatar
plumpzz
Is ur car a pre 05? It happened to my car ALL the time prior to CD009 tranny (which happens to include a new slave cylinder!). After that, it NEVER happened again. As a matter of fact, the new clutch feels SO much better, it deterred me from wanting to upgrade clutches.
Old Apr 28, 2007 | 08:35 PM
Not to change the subject but where are the time slips?
Old Apr 29, 2007 | 01:57 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
I switched to steel braided lines and motul high temp fluid and it never did it again.
Old Apr 29, 2007 | 02:13 PM
ZROCKET's Avatar
ZROCKET
In the car. I'd scan them, but my scanner won't work with Windows XP. Anyway when I have some time I'll see If I can take a picture of them and upload. Oh, the run when the clutch FU was 23.077
Old Apr 29, 2007 | 02:21 PM
At least you crossed the finish line.
Old Apr 29, 2007 | 02:27 PM
ZROCKET's Avatar
ZROCKET
The car is a 2005 35th An. 6Speed. Revup Motor 300hp. No mods, except a clear bra. Soon to change. I was going to change the fluid in the slave cylinder to Motul Syn. Stainless steel line, Chrome moly pivot ball, engine dampner. Hopefully the clutch is not damaged to badly. If it is, I'll go with a high performance packge from JWT or SGP. I plan on putting Nitrous on it initially to shut people up at the track.
Old Apr 29, 2007 | 02:51 PM
ZROCKET's Avatar
ZROCKET
Maybe I could go to the Stealership for service and say, Oh bye the way could you check out the clutch because it stuck to floor when I was driving it. I just won't mention I was at the Drags doing burnouts and rapping it out at 7000 RPM when it FU. Maybe I could get a new clutch for free. But you know what, I'm so disappointed with the clutch I dont want a stock one even if it was for free.
Mattg350z
Oct 2, 2015 06:51 AM
