Drag NHRA, IDRC, IHRA, NDRA
First time at the track =P
Old Sep 5, 2007 | 06:45 PM
Aced16's Avatar
Aced16
Default First time at the track =P
well i went to orlando speedway tonight and ran down a quater mile track for the first time! my car is completely stock, but i wanted to see what i can do, and what i can improve on... well here are the stats, be nice all but any info would help...
04 g35 coupe 6mt
Best run
rt....575
60...2.336
330...6.336
1/8...9.546 @ 77.21
1000... 12.275
1/4.... 14.568 @ 99.77
My rt's went down each run but my 60's got worse i ran a consistent 14.5 all night. all in all i had a great time, and practice is def in order but i want to hit low 14's stock! so till next time...
Old Sep 5, 2007 | 06:58 PM
plumpzz's Avatar
plumpzz
Its the 60 foot thats weak, but not bad for a first attempt. Ive seen people in the 15s. I was lucky, my first attempt has been my best so far.
Old Sep 5, 2007 | 07:02 PM
Was the emergency brake OFF?
Old Sep 5, 2007 | 07:17 PM
blktrack350's Avatar
blktrack350
well orlando speed world is not the greatest track in the world. i use to go about 2 times a month back when i first got my z. you could get low 14's easy if you droped that 60 down. not bad for your first time
Old Sep 5, 2007 | 07:18 PM
On a more serious note, the car is running strong picking up 22 MPH in the second 660-feet. As plumpzz mentioned, 60-foot time is hurting ET. So is ambient temperature. I can definitely see 13.99 seconds in the fall.
Old Sep 5, 2007 | 09:30 PM
Aced16's Avatar
Aced16
any recommendations to help my 60ft?
Old Sep 5, 2007 | 09:40 PM
Nexx's Avatar
Nexx
reaction times have no bearing on your final time. the timer doesnt start until your car moves foward.
Old Sep 6, 2007 | 12:08 AM
bacalhau16's Avatar
bacalhau16
We cant recommend anything to you unless you let us know how you are launching to begin with. Are you picking and RPM and slipping the clutch. Are you dumping the clutch? What PSI is in your tires? All that good stuff.
And like Nexx said basically, forget about your RT unless you are bracket racing which you are not.
Old Sep 6, 2007 | 06:35 AM
ct350z's Avatar
ct350z
practice,practice,practice!!!!
Old Sep 6, 2007 | 09:19 AM
Datona Jess's Avatar
Datona Jess
Try reducing your rear tires to around 26psi...
Remove your tire, jack, and all excess crap in the car....
Then go give it another try.
Practice is the best thing, ohh darn...
Old Sep 6, 2007 | 10:05 AM
Aced16's Avatar
Aced16
last night i experimented with a 2000,2500, and 3000 rpm launch. my best 60 was with the 2500. as much as i would love to say i am slipping it, i may have dumped it out of excitement lol but what PSI should i be at, i didnt drop my tires at all. also what kind of techniques do you guys use?
Old Sep 6, 2007 | 05:14 PM
Peak350's Avatar
Peak350
Stock tire pressures have served me VERY well. A stiff sidewalled tire doesn't like to be dropped the same way a wrinkle wall does. VeeTec was saying the same so I know I'm not alone here.
A good clutch slip from 3500-5000 does the trick for me
Old Sep 6, 2007 | 06:51 PM
Different tires, different staging pad preparation, different ambient temperature will require different tire pressure. If you drive to the dragstrip, remember that you will be measuring hot pressure. Begin the day with 34 PSI. Drop tire pressure 2 PSI after each run. You will find a sweet spot.
Keep in mind that dropping tire pressure increases rolling resistance.
Old Sep 7, 2007 | 05:12 AM
Peak350's Avatar
Peak350
The way I convinced myself to run 35 psi and keep it (aside from having faster 60' times....I was trying to blame better track prep) was that I did a quick launch on a backroad, and rather than leave a full width tire mark, there were marks from the edges of the tire where the sidewalls were forcing it down.
There is a spot that will work best, but honestly I've never (3 different tire types, Dunlop SP2000, Toyo T1-R, and now the RE050A) gained anything by dropping below 30 psi.
Old Oct 2, 2007 | 09:38 AM
Datona Jess
I had good luck with 28-30psi.
I like to start lower and then work my way up personally.
It is all about finding the spot.
Let us know how you do next time you go out
Good luck, and don't get discouraged.
Old Oct 2, 2007 | 10:24 PM
PFI350Z's Avatar
PFI350Z
for the best launch... reduce it to 20psi!!!!!!
Old Oct 3, 2007 | 06:48 PM
Peak350's Avatar
Peak350
Hint hint....don't listen to everyone.
Veetec mentioned he ran stock tire pressures, I couldn't believe it, gave it a shot (do a scrub your tires tire spin in the burnout box) and I have been able to pull 1.9's consistently.
Radial tires with stiff sidewalls (aka potenzas) don't like low pressure - they grip better with 35 psi.
Old Oct 3, 2007 | 06:56 PM
How does this technique work for you? Post a time slip.
https://my350z.com/forum/drag/233840-top-25-1-4-mile-times-for-tt-st-supercharger-nitrous-bolt-ons-stock.html
Old Oct 3, 2007 | 06:57 PM
https://my350z.com/forum/showthread.php?t=233840
Old Oct 3, 2007 | 07:06 PM
lafabritto350z's Avatar
lafabritto350z
did u by any chance run an M3?? my friend txted me about it because im tryingt o get a 350z and he is tryingt o get an m3 and since the g35 is pretty close he txted me... M3 14.3 @97 g35 14.8 @91 which m3 did u run??
