my tt at the track for the first time....
You have a similar set up to me I have JWT TT I run 19" wheels I air them down to 20psi which is quite low but seems to work for me. I avoid the water box and give the tires a quick spin too get any debris off of the tires. I tried several launches from 4000rpm working my way down. My best 60' was 2.09sec that was launching about 25-2700rpm anything more resulted in massive wheel spin. I run 12.7-12.9 @ 112mph range at 2190ft altitude. However as someone said eairlier you learning curve will be steep your first few trips to the track. It may be a little dissapointing but your goal should be to keep showing steady improvment 3-4 trips to the track you should shave lots of time off your original et. Good luck and fave fun.
