Drag NHRA, IDRC, IHRA, NDRA
New HR Trap speed record set, several times....
Old Nov 12, 2007 | 11:19 AM
  #41
warmmilk's Avatar
warmmilk
thats an amazing trap, congrats
Originally Posted by HDPD350Z
VeeTec, all I have to say is congrats on the amazing stock time/trap. However, you do not hold the record, according to this post...
https://my350z.com/forum/showpost...7&postcount=67
nowhere in the post is his trap speed mentioned, only his ET, which is most likely BS
Old Nov 12, 2007 | 12:00 PM
  #42
DouBLeJ16's Avatar
DouBLeJ16
Awesome trap speed.
Old Nov 12, 2007 | 12:04 PM
  #43
Datona Jess's Avatar
Datona Jess
Great runs, and pretty consistent too!!
Great goal to shoot for
Can't wait to get my 08...
Though I am the limiting factor I think....hahah
I do agree the Holden front on the GTO is AWESOME!
Old Nov 12, 2007 | 04:52 PM
  #44
VeeTec's Avatar
VeeTec
Originally Posted by Diesel350
Switch your clutch fluid to Motul 600 High temp fluid. Problem solved.
You are most likely boiling the clutch fluid with all those hard launches. Also replacing your clutch line to SS will also add protection from your clutch fluid from overheating. I did this and never had a problem since with the clutch sticking.
I thought about that, but I want Nissan to fix the problem, and the car to remain stock.
Since the event, my clutch pedal pressure drops with little effort at times. It was a little better today, but it's still not springing up like it was. It just doesn't seem like the fix would be so hard that Nissan couldn't come out with one fairly quickly. I wish they would wake up. Even Road and Track commented about the problem, with the G37, which apparently has the same set up.
Old Nov 12, 2007 | 04:54 PM
  #45
bacalhau16's Avatar
bacalhau16
That just sucks. Would it be possible to just take the slave cylinder/clutch assembly out of an 03-05 and get it to work?
Old Nov 12, 2007 | 04:57 PM
  #46
bboypuertoroc's Avatar
bboypuertoroc
I was thinking that too, but if it were that simple you'd think someone would've done it by now. Hell, I'd give it a shot if I had an '07 Z. I think since eveything is changed in there that the mounting points are most likely different (kinda like trying to put a 1g tranny in a 2g... same tranny, different mounting points for everything).
Old Nov 12, 2007 | 05:30 PM
  #48
Diesel350's Avatar
Diesel350
Oh definitely take it to the dealer first and see if it could be anything else like the master clutch cylinder but they are going to be asking you what causes the problem and what are you going to tell them? That you were launching the car at the track? LOL
If they do inspect it and don't find any problems then you will just have to replace the fluid to high temp.
Old Nov 13, 2007 | 06:46 PM
  #49
warmmilk's Avatar
warmmilk
a little off topic, but i was looking at ur slips again and it look like the right lane is sponsored by: "**** FORD"
that right? pretty funny
Old Nov 13, 2007 | 08:52 PM
  #50
VeeTec's Avatar
VeeTec
Cook.
Old Nov 14, 2007 | 06:00 AM
  #51
warmmilk's Avatar
warmmilk
ahh, i c, that makes sense now
Old Nov 18, 2007 | 04:15 PM
  #52
Pat Bateman's Avatar
Pat Bateman
VeeTec, are you in 4th gear at the end of your runs?
Old Nov 18, 2007 | 04:52 PM
  #53
kleefton's Avatar
kleefton
He's gotta be. Third gear can not go 107mph in stock form.
Old Nov 18, 2007 | 04:56 PM
  #54
rkemp1's Avatar
rkemp1
+1
I just got back from the track with my HR today and I'm in 4th with mine. All i have is intakes.
Old Nov 18, 2007 | 09:23 PM
  #55
VeeTec's Avatar
VeeTec
Yes. I shift at redline.
Old Dec 1, 2007 | 01:37 PM
  #56
Pat Bateman
Default Newer record
Hey VeeTec, I'm not trying to hijack but rather add to your post. I went to Cecil County Dragway in MD last night, it was the last night of the season so I'd regret it if I didn't go. It was cold out, averaged about 35 degrees, not 59 like the slip says.
My highest trap of the night for my 07 Base was 107.23, still 100% stock.
I did manage to trap over 107 four times.
Attached Thumbnails New HR Trap speed record set, several times....-time-002.jpg   New HR Trap speed record set, several times....-time-003.jpg   New HR Trap speed record set, several times....-time-004.jpg   New HR Trap speed record set, several times....-time-005.jpg
Old Dec 1, 2007 | 03:08 PM
  #57
itsjiggajames's Avatar
itsjiggajames
those are some good runs.. contact the moderator in this section and have those times posted on the top 25 07 bone stock times..
Old Dec 3, 2007 | 04:01 PM
  #58
VeeTec's Avatar
VeeTec
Congrats!
That just backs up my comments on the 07. With a good 60', you will be down in the low 13's easily. Just work on that launch.
That even edges my 107.19, and I also ran over 107 a few times, during my last track event.
Old Dec 3, 2007 | 04:29 PM
  #59
tornatic!!'s Avatar
tornatic!!
Congrats!
I'm trying to catch you Warren before you mod that beast!! After full exhaust and a good tune I think my GTO will give you a better matchup. There 's a '04 GTO A4 with full exhaust, intake, and a tune that ran a 13.0 at 108. Hopefully I can get close to that.
Old Dec 3, 2007 | 04:34 PM
  #60
Pat Bateman
Thanks VeeTec,
My best run of the night didn't come with a 107 trap, it was 13.465@106.86 but it came with a 2.227 60'. I've been having a hell of a time trying to get a better launch than the 2.2 range.
So I'll ask, How the hell did you manage to pull a 1.984 60' on stock tires, no lsd?
