Drag NHRA, IDRC, IHRA, NDRA
12.7 @112 JWT TT G35 Stock block W/Stillen true dual
Old Jan 15, 2008 | 03:09 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Default 12.7 @112 JWT TT G35 Stock block W/Stillen true dual
Just thought I would share. As title says stock block JWT TT kit with a Skunk II spacer, Stillen true dual exhaust with Fast intention resignated test pipes. I thought 12.7 @ 112 with Jim Wolfs base tune at 6.8psi on street tires was decent considering the 2230' Density Altitude.
Attached Thumbnails 12.7 @112 JWT TT G35 Stock block W/Stillen true dual-copy-of-track-001.jpg   12.7 @112 JWT TT G35 Stock block W/Stillen true dual-copy-of-track-002.jpg   12.7 @112 JWT TT G35 Stock block W/Stillen true dual-copy-of-img_1452.jpg   12.7 @112 JWT TT G35 Stock block W/Stillen true dual-castrol-raceway-oct-8-07-001.jpg   12.7 @112 JWT TT G35 Stock block W/Stillen true dual-scc-small.jpg
Old Jan 15, 2008 | 03:17 PM
singh's Avatar
singh
_______________
So how much horsepower is 6.8psi putting down?
Old Jan 15, 2008 | 03:57 PM
eltness350's Avatar
eltness350
The Untouchable
im gonna guess....350-360rwhp ish??
Old Jan 15, 2008 | 04:15 PM
jksstar's Avatar
jksstar
https://my350z.com/forum/videos/328578-jwt-tt-g35-stock-block-w-stillen-true-dual.html
not to sure what it would be on a dynojet
Sylvan Lake V35, good run man and its a nice looking car
Old Jan 15, 2008 | 04:59 PM
eltness350's Avatar
eltness350
The Untouchable
dam...i only guessed that since i went 12.3 with dr when i had my procharger setup around that hp....
Old Jan 15, 2008 | 05:38 PM
Sylvan Lake V35
Street tires and poor track prep kept me from launching I had to leave the line at 2000rpm in order to keep me from spinning the tires excessively. The Density Altitude was 2230' at closer to sea level the times would most likely be faster.
Old Jan 15, 2008 | 06:37 PM
eltness350's Avatar
eltness350
The Untouchable
gotcha.....so when r u gonna bump up the boost??!!
Old Jan 15, 2008 | 07:05 PM
Sylvan Lake V35
I just bought a new house so funds are a little tight right now but I am planning on a Haltech soon(before summer) and drag radials. I would hopefully running 9psi what would you reccomend am I going overboard with 9psi on a stock block? I am not sure 8psi would be much of a diffrencefrom 6.8psi horse power wise. Also note this is all done on crappy 91 octane(the best we get in Alberta)
Old Jan 16, 2008 | 12:14 PM
scotts300's Avatar
scotts300
Well done, although I would have expected a slightly higher trap given 395rwhp/375rwtq. Keep on working at it! Run the DRs, and if you "bump" the boost, buy 100 octane race gas! 91 is the pooh, and the VQ is prone-and-known to blow up.
Old Jan 16, 2008 | 03:38 PM
eltness350's Avatar
eltness350
The Untouchable
nice powa...as for boost...i did one summer with my procharger at 7psi...went 12psi for another....then got a tn st at 8 psi then the motor gave.....3 summers of beatings got it...but there are people running more power with no problems...guess its a guessin game...8-9psi i would say should be good and pretty "safe"...
Old Jan 16, 2008 | 04:15 PM
DMK's Avatar
DMK
Good times. Is this the 530BB kit? What kind of power are you putting down?
Old Jan 16, 2008 | 09:35 PM
scotts300's Avatar
scotts300
Dude, read the thread...
Old Jan 17, 2008 | 05:24 AM
Datona Jess's Avatar
Datona Jess
Nice number especially on that little of boost
Keep us all informed on your progress.
Nice looking G by the way!
Old Jan 19, 2008 | 01:29 PM
Sylvan Lake V35
Thanks for the comments guys! A few people seem to think it should be running faster I thought that it was above what was expected out of this set up on a G35(heavy) at this altitude. I will update in the spring with hopefully a few changes to my set up and maybe a trip to a track closer to sea level.
Old Jan 19, 2008 | 06:30 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I think you did well. As mention elevation & weight are key factors people forget. Why I hardly post times from Bandimere (5500 ft).
Old Jan 24, 2008 | 01:14 AM
DMK's Avatar
DMK
Still doesn't mention which kit. 530BB or 700BB?
Old Jan 24, 2008 | 06:07 PM
TheCajunStyle's Avatar
TheCajunStyle
Glad to see a fellow JWT TT owner tearing up the track!
Old Feb 12, 2008 | 08:33 PM
Sylvan Lake V35
Thanks.
DMK its the 530 kit on the waste gate springs 6.8psi.
Old Feb 13, 2008 | 01:51 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Sylvan; Are you running the Stillen X-Pipe as well? Any dyno numbers?
Old Feb 13, 2008 | 06:43 AM
scotts300's Avatar
scotts300
https://my350z.com/forum/showpost.ph...51&postcount=4
