Drag NHRA, IDRC, IHRA, NDRA
Drag radials or ET Streets on a base?
Old Jan 24, 2008 | 11:49 AM
rkemp1's Avatar
rkemp1
Originally Posted by VeeTec
With open differential, one quick burn out only really heats up one tire. Two, will usually assure the other tire heats up, as the one side is biting now.
I dont know enough about differentials and the physics behind it all, but I can say that no matter what I seem to do I always seem to spin my right tire where the gas tank is. Will this change with DRs so that the one thats already heated up will stick after the first burnout?
Old Jan 24, 2008 | 02:08 PM
scotts300's Avatar
scotts300
I don't know. I usually just do one big ole' burnout like this (My car, me driving)
Long burnout Scott
(398)
Old Jan 24, 2008 | 03:56 PM
rkemp1's Avatar
rkemp1
Long burnout Scott
(398)
I could be wrong but it looked like smoke was coming from both of your rear tires so it looks like you have a limited slip differential. If so I dont think Veetec's 2 burnout rule would be directed at you. It is directed to us poor folks who only have one tire spinning at a time due to an open differential.
Old Jan 24, 2008 | 10:23 PM
scotts300's Avatar
scotts300
Yup. VLSD, actually. It roasts diffs though, so it ends up being a peg leg like you guys after a few runs...
Old Jan 24, 2008 | 10:27 PM
VeeTec's Avatar
VeeTec
Yes, because when you heat up a MT DR, it will bite.
Old Jan 25, 2008 | 05:42 PM
QuadCam's Avatar
QuadCam
Originally Posted by davidv
I see no direct relationship between LSD, no LSD and 60-foot times. Look at 300 horsepower American muscle drag races. Many have a solid rear axle.
Sorry for picking on you, but comments like this are so common. I think that alot of import guys don't understand anything about American "muscle" cars or solid axle suspensions.
The other good one is watching an import guy try to figure where the cam is on a pushrod V8, and then see the look of puzzlement when you explain where it is and that ther isonly 1 cam in the engine, too.
Old Feb 2, 2008 | 02:37 AM
WalkerT's Avatar
WalkerT
Professional
So it would be two burn outs infront of the water box?
What psi do you recomend? DR
Old Feb 2, 2008 | 06:21 AM
rkemp1's Avatar
rkemp1
+1 good question, I completely forgot about tire pressure.
Old Feb 2, 2008 | 08:05 AM
coachk's Avatar
coachk
I usually start out with 15psi on M/T DR's and then see how the track is.
Old Feb 2, 2008 | 01:26 PM
rkemp1's Avatar
rkemp1
cool, thanx for the info.
Old Feb 4, 2008 | 09:33 AM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Good info on wheels and tires for drag racing in this section lately. Keep the good info and opinons comming guys. My plan was simply 18"drag radials but I am starting to reconsider after reading a few of the recent threads.
Old Feb 5, 2008 | 07:10 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Slicks and there ability to wrinkle the sidewall and absorb some shock are slightly easier on the car IMO than DR's that have stiffer sidewalls.
With that being said either set with an inexperienced driver can = axle snap off the line! In your situation because you are NA and likely will be for a while I would go with the DR"s. That way if you want to mess around you can mount them and go out, or drive to the track on them. Ive driven to the track a few time on ET streets and combined with steel belted tires up front its NOT a fun ride. Good luck.
Old Feb 5, 2008 | 10:10 AM
Gooey's Avatar
Gooey
I just like to comment that Dr's or slicks will NOT improve your driving. It took me a awhile to actually learn how to launch with them and cut the sub 1.9 60's
Dont expect to just go with slicks or DR's and expectin 1.7 60's
Old Feb 5, 2008 | 10:15 AM
one350zfan's Avatar
one350zfan
+1 It takes a while to believe that you can launch above 5000rpm's
Old Feb 5, 2008 | 12:10 PM
rkemp1's Avatar
rkemp1
This may be my inexperience talking but I haven't heard of NA guys snapping axles how does this happen and what can be done to prevent this from happening?
Old Feb 5, 2008 | 12:14 PM
rkemp1's Avatar
rkemp1
Nah, you know me I am a realist. I know this will take some time to get used to, I just want to invest in a set of dedicated drag wheels and tires. Plus since Im planning to become more serious about it I dont want to continue burning up my street tires racing.
Old Feb 5, 2008 | 12:16 PM
ACEMAN's Avatar
ACEMAN
Master
Thumbs up
Very true
I have snapped two axles in my quest for 12's
This is going to be the year
I also have a base, but switched over to a vlsd. Never ran on DR's though. Either one you decide to go with will be a improvement of street tires ONCE you understand how to launch with them. Cant stress preloading the drivetrain enough. Plus, dont let the guy next to you determine when you launch. Take as much time as you need. Clock does not start until you move in a test in tune setting.
Later
Todd
Old Feb 5, 2008 | 12:24 PM
  #38
rkemp1's Avatar
rkemp1
Preloading is basically letting off the clutch with the RPMs revved just before the point where the car is moving correct? This helps with the drivetrain shock I imagine?
as far as the 12s you will get it, its just a matter of time. goodluck with it as I hope to do the same myself.
Old Feb 5, 2008 | 12:28 PM
  #39
ACEMAN's Avatar
ACEMAN
Master
Correct, you dont want any slack in the drivetrain. Everything has tension on it.
Good luck
TOdd
Old Feb 5, 2008 | 01:04 PM
  #40
rkemp1's Avatar
rkemp1
sounds good, I experimented with that at the end of the season so I will make it a regular practice with the DRs or slicks whichever I go with.
