Drag NHRA, IDRC, IHRA, NDRA
Drag radials or ET Streets on a base?
Old Feb 5, 2008 | 02:02 PM
  #41
scotts300's Avatar
scotts300
Start at 12-15psi in the MT ET Streets, then work down to 10psi and see how it feels to you. Radial front tires will make for an interesting ride during the last 1/8th mile though.
Old Feb 5, 2008 | 02:09 PM
  #42
ACEMAN's Avatar
ACEMAN
Master
Very true, makes for a very boat like interesting ride
Old Feb 5, 2008 | 02:21 PM
  #43
Alberto's Avatar
Alberto
Cranky FI Owner
Nah-its not even a little scary NA, running 11's with my ST set-up it started getting scary (only in 4th) and now with my set-up its terrifying! Dont worry rkemp about the wobble NA 10Xmph is nothing to be scared of If you get something by the April 11th trackday I can give you some pointers that helped Todd drop some time...btw NA Id run 20-16psi, anything less is overkill for ther power levels IMO.
Old Feb 5, 2008 | 02:25 PM
  #44
ACEMAN's Avatar
ACEMAN
Master
And if you come out for the after party, i will give you some pointers that helped Alberto with beer pong and Vodka
Todd
Old Feb 5, 2008 | 02:49 PM
  #45
rkemp1's Avatar
rkemp1
Yeh unless technosquare finishes up the reflash for the HR I will only be at 107-109mph so Im not afraid of a little wobble. Im pretty sure I should have them by the track day so the tips would be much appreciated. By the way thanks for the reminder, just put myself on the Vacation calendar that day.
Old Feb 5, 2008 | 02:50 PM
  #46
rkemp1's Avatar
rkemp1
Todd
LMAO! I will be there for that too but I'm a boring non drinker
Old Feb 6, 2008 | 04:49 AM
  #47
WalkerT's Avatar
WalkerT
Professional
I have run slicks and it took a crap load of runs to launch out with a better than 2.2+. I just have not run on DR. I am giong to the track this Sat. and I will post up how I did. All my past runs were with my 05 so my first couple runs will be on street tires then switch over to the DR on the 07.
Thanks everyone for not flaming me for jacking rkemp1 thread
Old Feb 6, 2008 | 08:02 AM
  #48
scotts300's Avatar
scotts300
...getting scary (only in 4th) and now with my set-up its terrifying!
Wobbling at 120+ certainly makes the blood flow... You know it does. BTW, I made a "center cone" run like yours a few weeks back. Someone has a vid of it, but unfortunately I don't. It was certainly "interesting"
Old Feb 6, 2008 | 12:31 PM
  #49
Gooey's Avatar
Gooey
www.jegs.com russ
Old Feb 6, 2008 | 01:07 PM
  #50
rkemp1's Avatar
rkemp1
Originally Posted by Gooey
Yeh I checked em out and it seems I should be able to get a set for under 700. When looking through all the different types of drag radials and Mickey Thompson tires its a little overwhelming. I think I am going to have to stick to drag radials though because I wont be able to swap wheels at the track. I gotta have something I can drive from home to the track.
Any suggestions for good drag radials?
Old Feb 6, 2008 | 01:31 PM
  #51
Gooey's Avatar
Gooey
$700??? I picked up my 15" jegs wheels for around $220. That was forthe 2 rears. And I believe DR's or Et' Streets go for around 150-170 each
Old Feb 6, 2008 | 03:05 PM
  #52
rkemp1's Avatar
rkemp1
The wheels were priced around 170 each if I was looking at the right ones anyway. I looked at it pretty quick. Ill take a second look
Old Feb 6, 2008 | 03:10 PM
  #53
rkemp1's Avatar
rkemp1
my bad looks like 124 each for 15x8s so thats still almost 600 with tires then for shipping and lugs Id imagine it would be right around 700. Did you get some kind of discount for the wheels?
Old Feb 7, 2008 | 07:30 AM
  #54
scotts300's Avatar
scotts300
Get ET Streets or ET Street Radials. The latter will give you the best ride to/from the track, all you need to do is lower the tire pressure. Check around for availability from other vendors for them as well, as I've found Jegs to be the most expensive for most products across the board.
Old Feb 7, 2008 | 07:54 AM
  #55
rkemp1's Avatar
rkemp1
I will definitely shop around, but almost everyone I have talked to has told me Jegs has pretty cheap drag radials and wheels but I guess we will see. Thanks for the info.
Old Feb 7, 2008 | 10:35 AM
  #56
__jb's Avatar
__jb
Z + Rear Seat
Jegs has been out of the MT ET Street Radials for quite a while now. I've tried a couple of other places and they are out too. Latest from Jegs is that they will get a new shipment in on 2/15. They were supposed to get a shipment in on 1/31, but that never happened.
Apparently Mickey Thompson has been bought out by some other company and production is down (according to the people at Jegs).
Old Feb 7, 2008 | 11:57 AM
  #57
rkemp1's Avatar
rkemp1
damn that sucks to hear. hopefully they will get a new shipment by the end of february.
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
