Drag NHRA, IDRC, IHRA, NDRA
drag radials
Old Aug 25, 2008 | 05:00 PM
athenG's Avatar
athenG
did your 245 held up when launching hard? how hard did you launch your car?
Old Sep 2, 2008 | 07:30 AM
95snoozer's Avatar
95snoozer
Is that even helpful at that point? I was contemplating whether or not I should get 295s for my stock 18"x8", but damn.
no reason to go larger than a 275 at all. you will get cupping when you dropp the pressure and will not make full use of the tread
The compound and sidewall flex of your tire will make far more difference than adding 20 mm of width that probably wont even touch the ground.
going from a run flat 245 to a DR 245 is a massive difference if you use the tire correctly. I.E. 16-20 psi with a smoky burnout and lots of practice on launching without bogging your car. you should be able to pull 1.9s all day without launching correctly. Learning to drive could get you as low as 1.6s depending on track prep, power and technique
Old Sep 2, 2008 | 08:04 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Yeah, I gave up on that idea. I think I'm going to go back to slicks when I get enough money.
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
rizzla
Drag
Sep 17, 2015 08:44 AM
12SecZ
Oct 8, 2003 08:56 AM
