Drag NHRA, IDRC, IHRA, NDRA
tire advice for occasional dragstrip visits?
Old Oct 6, 2008 | 09:03 AM
idrive_MD's Avatar
idrive_MD
Default tire advice for occasional dragstrip visits?
I have an extra pair of 17x8+24 wheels I plan on using for occasional visits to the drag strip. I dont want an all out drag-slick, so I was thinking of maybe a drag-radial or a sticky tire one would use in auto-x or something like that.
Any suggestion on size and tire type for g35-coupe fender fitment?
245/45/17:
Kumho Escta V700 (Competition) 50 A A $189ea
Bridgestone RE-01R 140 A A $164ea
Sumitomo HTR Z 160 A A $66ea
Kumho Escat XS 180 AA A $150ea
255/40/17:
Sumitomo HTR Z 160 A A $79ea
Kumho Escta V700 (Competition) 50 AA A $198 ea
Yoko Advan A048 60 A A $257ea
Bridgestone Potenza RE070 140 A A $224ea
Advan Neova AD07 180 AA A $238 ea
Bridgestone RE-01R 180 A A $220ea
275/40 (is that too big):
Sumitomo HTR Z 160 A A $88ea
BFGoodrich G-Force TA Drag Radial-2 0 BC $187ea
Kumho Escta V700 (Competition) 50 AA A $214ea
I didnt include the Nitto Drag Radial because I have heard a lot of neg comments about it, but if you think it'd be better than a sticky competition tire or street radial voice it up. I'll probably manage maybe 4-6 times out to the strip with these tires and they will only ever be used for going to and from the strip.
Old Oct 6, 2008 | 10:01 AM
scotts300's Avatar
scotts300
I would go with a BFG TA DR in 225/45/17, as I think the 275/40 is too big for an 8" wheel. These can be driven to/from the track on your 8" wheel without issue. Just lower the pressure, do a good burnout, and go. All the other street tires are worthless if you are trying to get grip-on-launch. If you were interested in sourcing a set of 9" wheels, then you could go with the 275-sized tire.
Old Oct 6, 2008 | 11:25 AM
idrive_MD's Avatar
idrive_MD
I didnt think to go a size smaller, I guess in drag, smaller with higher grip is better than wider with less grip, makes sense...price on those TA/DR's isnt too bad either, thanks!
Old Oct 6, 2008 | 11:40 AM
garym's Avatar
garym
If you run a taller tire, you're 60' time usually won't be as good, but you'll have a higher trap speed at the finish line.
I run a taller tire to get a faster trap.
But that is just my preference and opinion.
Old Oct 6, 2008 | 12:50 PM
scotts300's Avatar
scotts300
The taller sidewall on the DR will allow for better weight transfer to the rear, aiding in grip, and overall ET.
Old Oct 6, 2008 | 03:46 PM
Blk03G35's Avatar
Blk03G35
General Exclaim UHP 255/40ZR17's - 109 a pop and as sticky as Nitto 555's
Old Oct 7, 2008 | 11:23 AM
idrive_MD's Avatar
idrive_MD
appreciate the advice guys
general exclaims really aren't comparable to what I was looking for, same for the standard Nitto 555. I was looking for Drag Radials or a sticky R compound type tire. The Nitto tire I was trying to avoid was the 555-DR which I've never heard a good thing about.
Old Oct 8, 2008 | 08:27 AM
blktrack350's Avatar
blktrack350
mickey thompson et street best drag radial out there.
Old Oct 9, 2008 | 09:04 AM
jmaestre23's Avatar
jmaestre23
275/40 WILL fit on an 17x8........trust me
Old Oct 9, 2008 | 09:05 AM
jmaestre23's Avatar
jmaestre23
thats what I have......275/40 on a 17x8
Old Oct 9, 2008 | 09:08 AM
2007 Z's Avatar
2007 Z
Old Oct 9, 2008 | 09:18 AM
Alberto's Avatar
Alberto
Cranky FI Owner
265/40 BFG DR will work fine on an 8" rim.
Old Oct 9, 2008 | 10:02 AM
scotts300's Avatar
scotts300
...and it's too big. "Fitting" on is one thing, having it fit on snugly, safely, and without much sidewall bulge is a different story. I know I don't want my sidewalls all bulged out when trying to get a good drag launch. You don't need a big tire at this HP level, just something sticky. There are guys that cut 1.5x 60' times with 600rwhp on a 255/50 MT ET SR.
Old Oct 9, 2008 | 10:04 AM
scotts300's Avatar
scotts300
Which one comes in the 265 size? I only see 275.
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
