Drag NHRA, IDRC, IHRA, NDRA
My 07 350Z vs. 07 WRX STI drag race
Old Oct 25, 2008 | 05:41 PM
infinite's Avatar
infinite
Default My 07 350Z vs. 07 WRX STI drag race
This is my 1st drag race.
I'm car #1027
Old Oct 25, 2008 | 05:44 PM
04LIQUIDSILVER's Avatar
04LIQUIDSILVER
get out stupid old man...
Old Oct 25, 2008 | 05:45 PM
You done good. Room for improvement in 60 foot time. Good ET.
Old Oct 25, 2008 | 05:48 PM
citymunky's Avatar
citymunky
Ha Ha,
Old Oct 25, 2008 | 05:55 PM
infinite's Avatar
infinite
it was my very 1st run on the drag strip. I ran my tires at 36psi cold. I'll run the rears at 30psi cold next time.
on my 2nd race I was 2.1 for the 60ft.... I hope I can get around 1.7 or better for a 60ft.
Old Oct 25, 2008 | 07:22 PM
brady's Avatar
brady
Originally Posted by infinite
...I hope I can get around 1.7 or better for a 60ft.
Now that would be spectacular.
Old Oct 25, 2008 | 07:26 PM
d1mon3k's Avatar
d1mon3k
Nice spanking of that STI, I hate those things!
Old Oct 25, 2008 | 07:55 PM
Alberto's Avatar
Alberto
Cranky FI Owner
The STI missed the 2-3 shift
Old Oct 25, 2008 | 08:18 PM
scmtkings4's Avatar
scmtkings4
311 whp?
Old Oct 25, 2008 | 08:44 PM
blktrack350's Avatar
blktrack350
you going to be running D/R's or Slicks?
Old Oct 25, 2008 | 08:53 PM
Alberto's Avatar
Alberto
Cranky FI Owner
No NA auto 350Z will hit a 1.7 60ft lol, that is not a realistic expectation.
Im guessing the dyno is from Church Automotive
Old Oct 25, 2008 | 09:00 PM
Sean's Avatar
Sean
https://my350z.com/forum/vq35hr/3912...no-inside.html
Old Oct 25, 2008 | 09:23 PM
infinite's Avatar
infinite
Drag radials. I was probably a bit too optimistic on the 60ft' times. but 1.8-1.9 is ideal
Old Oct 25, 2008 | 09:38 PM
infinite's Avatar
infinite
my better race... 2nd race ever.
R/T: .621
60': 2.104
330: 5.739
1/8: 8.680
MPH: 82.75
Old Oct 25, 2008 | 10:38 PM
R/T: .621
60': 2.104
330: 5.739
1/8: 8.680
MPH: 82.75
Significantly better. Nice driving.
Old Oct 25, 2008 | 11:37 PM
infinite's Avatar
infinite
Thanks.
I don't know what to do to improve my 60ft. if I go to hard on the throttle while reving reving to 1.5k-2k with one foot on the break, I get some wheel hop/spin/, if I rev higher the problem gets way worst, moonwalk status lol. On my best run I went part throttle and delayed full throttle all coming from Idle I think.
How do you guys running 2's and less do it? do you play it by feeling the grip before you go all out WOT or is it something else?
Old Oct 26, 2008 | 06:48 AM
On street tires? Staging pad conditions. Race regularly for several years and you'll figure it out.
Evenings in the spring and fall are poor. The temperature drops considerably after sundown, and condensation covers the staging pad.
If a incident occurs on the staging pad (such as a oil spill), the officials will of groom and spray with VHT. The pad will be “sticky” for the next 10 racers.
If you are having traction problems, switch lanes or move to the right or left of the well worn tire patch.
I like when the sun is overhead at about noon, and the temperature is about 60 degrees.
Judging staging pad conditions, DA and ET (a necessity of bracket racers) is part science, part experience, and part voodoo.
Old Oct 26, 2008 | 09:44 AM
infinite's Avatar
infinite
I'll give that a try, thanks.
Track elevation: 250' above sea level
Air Temperature: 78.1 F
Barometric Pressure: 29.94 inches Hg
Relative Humidity: 14%
Density Altitude: 1574 feet
Relative Density: 95.47 %
Old Oct 26, 2008 | 10:08 AM
pimpsahab's Avatar
pimpsahab
If your on street tires, just burn them up enough to get rocks off and such, and when its time to launch just flash the converter and go
Old Oct 26, 2008 | 08:08 PM
infinite's Avatar
infinite
GREDDY TT 5AT ON STOCK MOTOR...ALL DONE AT PERFORMANCE FACTORY!!! "Wouldn't you rather be blown by twins?"
