Drag NHRA, IDRC, IHRA, NDRA
Wheel/tire setup WITH Brembo brakes
Old Oct 26, 2008 | 07:57 PM
98intrigue's Avatar
98intrigue
Default Wheel/tire setup WITH Brembo brakes
I've already done the search...came up with inconclusive evidence.
I read that the Z32tt wheels do/don't fit.
FD Rx7 wheels do fit, but only one person mentioned it...that's not conclusive to me.
Alberto mention the Weld XP Pros, but they aren't made anymore.
So what are my options? In the past, I used BFG 265/40/18 DRs on my stock 18" wheels. I want a bigger sidewall and would prefer a wider wheel for a better contact patch.
Old Oct 27, 2008 | 02:53 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Pm Ray @ PFS
He has Brembo brakes and uses slicks but Im not sure what wheels his uses.
Old Oct 28, 2008 | 07:13 AM
scotts300's Avatar
scotts300
Z32TT wheels do NOT fit over Brembos rear calipers in all stock form. If you are set on using them, you might be able to file just a tad off the wheel spline assuming the balancing weights are not in the way. I did not try this, but it seems plausible, as it's just a couple of mm too small. If you can make that work, you can run the 16x10.5 or x11.5 MT ET Streets. That's what I use for much more HP.
This was discussed much here: https://my350z.com/forum/drag/214771...-wheels-2.html
Here are the pics. . .
Old Oct 28, 2008 | 09:22 AM
thom000001's Avatar
thom000001
good info
Old Oct 28, 2008 | 05:30 PM
Blackbird CPV35's Avatar
Blackbird CPV35
FD wheels do fit although they offset is a little bit too far in, I used them last year. This year I had a 17 inch Mustang cobra wheel that worked as well, but i need more sidewall
I would also be interested to see what kind of skinnies would clear brembos in the front
Old Oct 29, 2008 | 06:33 AM
scotts300's Avatar
scotts300
I thought the center bore of the Cobra wheels is not correct for ours?
Old Oct 29, 2008 | 06:52 PM
Blackbird CPV35
it looked a bit large, but i dont think hub centric matters much when ur only doing a 1/4 mile pass at a time
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
