Drag NHRA, IDRC, IHRA, NDRA
BAD trap speeds at the track
Old Nov 20, 2008 | 03:47 PM
Sirk17's Avatar
Sirk17
Default BAD trap speeds at the track
I went to the track last night for the first time since all the bugs were worked out of my car and had a good set of tires. The temp was a crisp 45 degrees and I was expecting 100+ traps finally.
Bam 98MPH AGAIN. I have nothing to blame it on but the car now. I've gone 14.2 14.3 and 14.4 all at 98 MPH. My mods are Full exhaust, test pipes, Kinetixs upper intake, cold air kit.
Any ideas..... and yes i know the ETs are a little low even for the 98 traps
Old Nov 20, 2008 | 03:52 PM
blktrack350's Avatar
blktrack350
wrong section but i am sure it will be moved. where are you shifting at? what does the rest of your slip look like? how do you launch? and what track did you go to?
Old Nov 20, 2008 | 03:59 PM
Sirk17's Avatar
Sirk17
Bithlow... 60 foots from a 2.2 to 2.38 and traps are always the same
Old Nov 20, 2008 | 04:14 PM
blktrack350
where do you shift at. traps should be around 100-102
Old Nov 20, 2008 | 04:55 PM
HDPDZO6's Avatar
HDPDZO6
Has your car been tuned since adding the mods? They can yank power from your car if not setup properly.
Old Nov 20, 2008 | 05:40 PM
ajcool2's Avatar
ajcool2
Actually that trap matches the ET's your running. Theyre just not normal for your mods.
Old Nov 20, 2008 | 07:55 PM
Sirk17's Avatar
Sirk17
No the car has no tuning done since the mods. Is there a reflash that can be done or will I need to get a "chip" tuned.
Also I'm shifting out at 6600
Old Nov 21, 2008 | 07:48 AM
I don’t see a time slip.
Old Dec 13, 2008 | 02:00 PM
ChrisR's Avatar
ChrisR
bithlow is orlando spin world. i went last night and couldnt get better than a 2.3 60 ft when i was getting 2.0s all day in SC....my best last night was 13.1 @ 110mph..with a 2.35 60 ft
Old Dec 13, 2008 | 02:14 PM
Thats a pretty impressive set-up. Most likely you will want to post your times here: https://my350z.com/forum/drag/233840-top-25-1-4-mile-times-for-tt-st-supercharger-nitrous-bolt-ons-stock.html
350z82
Oct 1, 2015 06:25 PM
