Drag NHRA, IDRC, IHRA, NDRA
Attempting to do Burnout with 2006 350z Track
Old Dec 1, 2009 | 03:29 AM
Bornatubby's Avatar
Bornatubby
Default Attempting to do Burnout with 2006 350z Track
Hi, i was at the track today, wanted to give the 350 a bit of a thrashing..
anyway.. i turned VDC off, dumped clutch, put foot on brake to do a nice standstill.. but the revs just dropped.. is it ABS?..
are you able to do burnouts in a 350z track 06?
advice please?
Thanks
Old Dec 1, 2009 | 04:02 AM
Armitage's Avatar
Armitage
You can't press the gas and brake pedal at the same time in the Z. It'll do a cutoff if you do, at least in my experience.
My350z peeps, please be nice to him, lol.
Old Dec 1, 2009 | 04:36 AM
Welcome. There are some helpful drag racing threads in the drag racing forum.
Old Dec 1, 2009 | 05:20 AM
Bornatubby's Avatar
Bornatubby
explain please. I'm open to flame cos im noob. I don't mind. fire away. Still want answers though. haaha
Old Dec 1, 2009 | 06:10 AM
VO...'s Avatar
VO...
Administrator
Oh lawd...
Old Dec 1, 2009 | 06:40 AM
lameophucnuckle's Avatar
lameophucnuckle
If you have clutch and brake pushed down at the same time and roll off the clutch into the brake jamming the gas you can do it. Once you get the wheels spinning a little then get "all up in that gas"...
If you just dump the clutch and stomp the brake the abs/vdc whatever you have will take over and cut power. (even if it's turned off)
OR dump the clutch turn the wheel and hang on! (burn outs in concentric circles are more fun anyway)
m
Old Dec 1, 2009 | 06:48 AM
How about a time slip?
What kind of tires are you "burning out?"
Old Dec 1, 2009 | 07:04 AM
DemitriHKS's Avatar
DemitriHKS
i've read in the past man that in order to do a burnout in the 6 speed cars there is a fuse you need to pull. I'm not sure about that but once you pull the fuse it will disengage what is stopping you from doing it. The AT's are a different story for some reason.
Old Dec 1, 2009 | 07:30 AM
kno's Avatar
kno
Hmmm what fuse might that be?
Old Dec 1, 2009 | 08:01 AM
Bornatubby's Avatar
Bornatubby
Cheers for the replies, so i am unable to do a burnout on the spot? as i cant have my foot on the brakes while giving the car acceleration... How do i do it then? Without cutting a fuse.. etc
kennedy's Avatar
kennedy
just roll off the clutch and hit the brake while in the gas way easier. if your on street tires then you should give them a quick spin ,doing a burn out will only be make things worse the tires will be greasy not sticky.
Old Dec 1, 2009 | 08:41 AM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Its the brake light fuse. I pull it for drag racing and then you can do a burn out with the brakes applied.
Old Dec 1, 2009 | 08:48 AM
adamciya350's Avatar
adamciya350
You don't need to ruin tires to impress the ladies, the z itself will do
Old Dec 1, 2009 | 08:52 AM
D-Mysta's Avatar
D-Mysta
you can remove the brake lame fuse (its a 10a red fuse on the driver side kickpanel next to your dead pedal it says brake lamp or something like that) then:
stick 2 wires in where the fuse goes
attach one to a switch
atach the switch to the fuse with a piece of wire
attach the other wire to other end of fuse
mount switch anywhere
https://my350z.com/forum/drag/193391...se-switch.html
solved
Old Dec 1, 2009 | 10:13 AM
CAB350z's Avatar
CAB350z
From personal experience 2003 touring as bad as it might be for the transmission gun it in first (Clutch drop at 3500 rpm and thats enough to keep my rear wheels spinning) and turn the wheel.
Old Dec 1, 2009 | 10:23 AM
03threefiftyz's Avatar
03threefiftyz
what's a burnout?
Fuse is actually called the stop lamp fuse. Only remove it on track.....you will not have brake lights.
Old Dec 1, 2009 | 10:46 AM
S8ER95Z's Avatar
S8ER95Z
what's a burnout?
Old Dec 1, 2009 | 11:50 AM
tylerxfire's Avatar
tylerxfire
question has been asnwered pull the brake light fuse in the car driver side left side under the dash...u wont have brake lights but u can do a burnout at the track so dont forget to put it back in..also u will get lights on ur dash dont be alarmed because everything is fine..burnout and run it....
but im assuming u are just running street tires, and street tires need little to no burnout and nothing smoky or they get more slippery so u really dont even need to do this...a rev and dump it a little to spin them a tad and clean the tires off and go...oh and dont drive thru the water box if u are running street tires go around
Old Dec 1, 2009 | 12:03 PM
03threefiftyz
Originally Posted by S8ER95Z
Weak........
Old Dec 1, 2009 | 01:43 PM
C5_vette's Avatar
C5_vette
what's a burnout?
Oooh can I play
