Drag NHRA, IDRC, IHRA, NDRA
First time @ drag strip
Old Dec 18, 2009 | 01:02 AM
  #41
*Boose*'s Avatar
*Boose*
With what he took out...you are talking....what...60 pounds. That amount is negligible in terms of 1/4 mile mph benefit. Like I said (and some of the locals in here) it seems as though a stock DE traps in the 102-103 range at this track.
But the fact is there 60's are alot better, and their back halfs are not 23 mph. With a 2.4 60' my car still trapped and my back half mph gain was 20 mph. Even with my car with no spare, jack, tire pressure in the rear at 20 psi, 2.1 60', front tire pressure at 35 psi, my car still average a back half of 20-21 mph also on a DA of -880 or something ridiculous like that.
OP are you WOT shifting or coming off that gas?
Old Dec 18, 2009 | 07:23 AM
  #42
03threefiftyz's Avatar
03threefiftyz
My car picks up 22-22.5 in the back half....24 does seem pretty unreal.
Old Dec 18, 2009 | 10:56 AM
  #43
209Z33's Avatar
209Z33
yah i'm let off gas when i shift know my E.T. pretty sad because got bald tires spinning 2nd n little bit in third n plus wasn't launch from the start creep out then floor it tried launch at 1.25k spin pretty bad plus see youtube video me you can hear how bad spinning off the launch
Old Dec 18, 2009 | 01:46 PM
  #44
03threefiftyz
Translation needed
Old Dec 18, 2009 | 02:25 PM
  #45
209Z33's Avatar
209Z33
If asking I'm not WOT when I shift let off gas complete when I shift and second when shift second gear I break traction and I can feel the rear slide either left or right
Old Dec 18, 2009 | 02:39 PM
  #46
scotts300's Avatar
scotts300
Just come down to San Jose and we'll do a friendly side-by-side to clear up any doubt about your huge increase in speed over the last 1/8th of the track. We could pop your car on the dyno at Z Car Garage while you're here to see if your car really is said freak, but if you pull on my car with those few bolt-ons and at your weight, you have a freak.
Old Dec 18, 2009 | 02:43 PM
  #47
C5_vette's Avatar
C5_vette
This.
considering his mods, compared to all of the Z's run on this site.. it just seems very off...
Old Dec 18, 2009 | 03:47 PM
  #48
209Z33's Avatar
209Z33
sure just pm
Old Dec 18, 2009 | 04:23 PM
  #49
ajcool2's Avatar
ajcool2
Hmm IDK maybe that 3 inch exhaust is getting it done. I'd definatly like to see a dyno of your car. Nice times btw.
Old Dec 18, 2009 | 10:46 PM
  #50
*Boose*'s Avatar
*Boose*
sure just pm
In for dates and results.
Old Dec 18, 2009 | 10:59 PM
  #51
*Boose*'s Avatar
*Boose*
The problem we're having is not your car's launching. We're trying to figure out how the heck you managed to gain 24 mph after the 8th mile. I shift WOT, spin some off the line, and only managed 21 mph. But thats, my 06 with pop charger only.
Old Dec 18, 2009 | 11:18 PM
  #52
*Boose*'s Avatar
*Boose*
2003 touring 6spd bout 75 degree
I'm calling bs on you being in the left lane with your Z. I'm looking at one of my 2.234 60' slips and heres how it looks. BTW I have a base 06 with no spare, jack, and 1/4 tank of gas.
Match my slip with the one on the right and left.
60' 2.234
330' 6.102
1/8 9.209
mph 79.37
1000 11.863
1/4 14.115
mph 100.55
Sorry I'm not seeing that Z in the left lane.
Old Dec 19, 2009 | 12:00 AM
  #53
209Z33's Avatar
209Z33
You can see all slip that I'm clearly car number 6311
60' 2.234
330' 6.102
1/8 9.209
mph 79.37
1000 11.863
1/4 14.115
mph 100.55
Old Dec 19, 2009 | 12:10 AM
  #54
*Boose*'s Avatar
*Boose*
I see that. But it just doesn't make sense. What did you run against? Was it a camaro or civic on the shot? Another Z?
Old Dec 19, 2009 | 11:16 AM
  #55
209Z33's Avatar
209Z33
think that one was against s2000 kept with me until shifted into third gear start walk away from him
Old Dec 19, 2009 | 11:31 AM
  #56
Jairen's Avatar
Jairen
Translation:
I think that one was against an S2000. He kept up with me until I shifted into third gear which was when I started to walk away from him.
Old Dec 19, 2009 | 11:56 AM
  #57
60' 2.234
330' 6.102
1/8 9.209
mph 79.37
1000 11.863
1/4 14.115
mph 100.55
You can see “11” from inside the Z on the windshield. I assume this is “6311.”
Old Dec 19, 2009 | 11:58 AM
  #58
*Boose*'s Avatar
*Boose*
I know, I know someone just figure out how so I can do it.
Old Dec 19, 2009 | 12:31 PM
  #59
209Z33's Avatar
209Z33
well i pm scotts300 and probably be doing the dyno after holidays so let guys and know when dyno the car. I posted result as soon as i can. Happy Holiday
Old Dec 19, 2009 | 04:30 PM
  #60
SniperHunter's Avatar
SniperHunter
60 pounds is the spare and tools. Another 90lbs of gasoline (120lbs is full, he had ~1/4 left). That's a total of 150lbs, and that's a whole lot of weight that you'll feel. And the fact that the guy is light, weighing only 150lbs, can also make a huge difference.
Also, I've seen a stock 2003 6-speed Maxima run a 13.9 @ 98MPH (the norm is usually mid-14s, 93-95MPH). It was complete luck, because he got lucky and stuck to the same hot trail laid down by a 9-second run before him. That could also be the case here. Regardless, the slip says what it says. He did it, no matter what the circumstance was.
Obadabot
Jun 18, 2023 11:31 PM
