Drag NHRA, IDRC, IHRA, NDRA
Plz help me choose which drag radial is better
Old Feb 25, 2010 | 06:46 AM
  #41
str8dum1's Avatar
str8dum1
well of course I was exaggerating the point and you'd need considerable equipment to do it in the 1st place.
Ya the IP has 2 bolt mounting which I bought bc the SP unit wasnt being actively sold when IP released theirs. Ohh well..
I just dont like how the rear subframe is hollow and pinches when you tighten down the brace. Not to mention you really shouldnt jack from the rear diff anymore, since all the car weight in on those bolts/alum subframe, since you are not compressing the diff mounts anymore....
Old Feb 25, 2010 | 10:07 PM
  #42
Reid@SP's Avatar
Reid@SP
Ahh yes, the standard trouble understanding sarcasm and emphasis over the internet. lol I get it now
We were actively selling the Diff Brace, just no one was advertising it! I found these pictures, knowing that we offer these, and couldn't find them posted anywhere. BAM!! Posted
Reid
Old Mar 11, 2010 | 05:25 PM
  #43
rrmedicx's Avatar
rrmedicx
Sub'd for updates.
Old Mar 11, 2010 | 07:21 PM
  #44
GodSpeed's Avatar
GodSpeed
Not all there
Originally Posted by Reid@SP
Here's the SP Diff Brace pics I promised!
Reid
can someone post a pic of where it mounts to above where these pics dont show?
Old Mar 12, 2010 | 03:59 AM
  #45
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Look harder....the pics show everything.
Old Mar 16, 2010 | 12:54 AM
  #46
Reid@SP's Avatar
Reid@SP
https://my350z.com/forum/engine-and-...brace-kit.html
I have more pics in this thread!
Reid
Old Mar 19, 2010 | 12:47 PM
  #47
ChuckD05's Avatar
ChuckD05
Quick Question... I have base 370z without sport brakes.. So I am going to go with a 15 inch wheel in the rear with MT or Hoosie DR ...
Im trying to keep my stock 19s (rays from sport model) on the front... the 275/60/19 tire is about the same size as stock... would it be better to run a 60 or 50 tire on the rear ???
again I plan to keep my stock tires up front on... 28.6 diameter i believe. the 60 series tire is 28" .....
thanks for the help! these threads have been very useful.
Old Mar 19, 2010 | 02:31 PM
  #48
Reid@SP's Avatar
Reid@SP
You are going to be running a radial up front and a bias ply out back. It is a bit tricky as the rear end will want to sway a bit, however if you are dead set on running this setup, get the Hoosier QTP as they are far more stable up top than the Mickey's.
It doesn't really matter what series sidewall you have, you don't need to keep it perfect with the fronts. The taller the sidewall in drag racing, the better traction you will have.
Reid
Old Mar 19, 2010 | 02:32 PM
  #49
Reid@SP's Avatar
Reid@SP
Originally Posted by rrmedicx
Sub'd for updates.
You're going to need all the tire you can get!!!
Old Mar 19, 2010 | 04:59 PM
  #50
rrmedicx's Avatar
rrmedicx
/\/\/\ I know. Thats why I started following these threads. Also FYI, I'm going with a widebody kit when I get the car back, so I can run wider rims/tires or different offsets if necessary to clear my BBK.
Reid, I am open to suggestions.
Old Mar 19, 2010 | 07:09 PM
  #51
Reid@SP's Avatar
Reid@SP
Randy, taller is more important than wider in drag racing, but going wider definitely won't hurt you!
Reid
EnjukuRacing
Sep 30, 2015 06:55 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Tochigi_236
Sep 27, 2015 03:40 PM
rizzla
Drag
Sep 17, 2015 08:44 AM
