Drag NHRA, IDRC, IHRA, NDRA
Need Some drag Pointers 06 5/AT Z
Old Apr 24, 2010 | 03:08 PM
motomadness910's Avatar
motomadness910
Default Need Some drag Pointers 06 5/AT Z
So I have only drag raced my car 2 times and the first time i raced I had:
KandN Intake, Motordyne plenum 5/16 Iso thermal,Top Speed exhaust
My best time was a 9.519 and my average run was around a 9.6
I went out again yesterday and I got berk hfc, megan racing y pipes dropped my tire pressure to 25 and a osiris tune and my best time was a 9.512 again i was all over between 9.512 and 10.00. Is there any pointers I can use I have tc off and I rev my car and even tried shifting at different points im upset that my et isnt much better but if theres any advice itd be nice.
Thanks guys Btw: the track is at qualcomm and is in a parkinglot its kinda preped but its not an ideal track for best times
Lights were a tree setup Below are from last night with everything installed on the car tire was dropped to 25 psi and did light burnouts on dry surface no through water
Fast time:
Vehicle Reaction: .659
60 Ft: 2.361
MPH: 76.39
ET: 9.519
Second fastest:
Vehicle Reaction: .839
60 Ft: 2.402
MPH: 76.01
ET: 9.620
Third:
Vehicle Reaction: .541
60 Ft: 2.426
MPH: 76.65
ET: 9.647
Fourth:
Vehicle Reaction: .765
60 Ft: 2.436
MPH: 75.76
ET: 9.692
Slowest Run:
Vehicle Reaction: 1.255 ( i must have taken a nap or something)
60 Ft: 2.537
MPH: 76.01
ET: 9.908
Lastly i have a dyno from when i got the tune I have been using the tiptronic and shifting as close to redline as i can by the looks of my dyno sheet where should i be shifting?
Thanks for the time/help guys
Old Apr 24, 2010 | 03:12 PM
03threefiftyz's Avatar
03threefiftyz
Post up the intervals (or slip).
Old Apr 24, 2010 | 03:40 PM
EDIT. My apology. I have no experience driving a automatic transmission.
Old Apr 24, 2010 | 04:46 PM
glenns280's Avatar
glenns280
Originally Posted by davidv
No time slips. No comments.
Old Apr 24, 2010 | 11:43 PM
motomadness910
Time slips up sorry ya that prolly would help
Old Apr 24, 2010 | 11:52 PM
Jairen's Avatar
Jairen
Was that you I raced last night? I was there in the white G35.
My best time last night was 9.0@80 with a 2.2 60ft.
Old Apr 24, 2010 | 11:56 PM
Jairen's Avatar
Jairen
3.7 final drive, Transgo, and drag radials and you'll be in the 8's.
Old Apr 25, 2010 | 12:16 AM
motomadness910
ya that was me what do u have in ur g35 ? You were car 4025 right? u ran a 9.4 and i ran a 9.8
Old Apr 25, 2010 | 12:45 AM
Jairen's Avatar
Jairen
Yep, I was 4025. That was my last run of the night. Lot's of wheel hop on that run.
Mods are:
5/16 spacer
Test pipes
X02 Exhaust
Osiris
To be honest, if you get your 60 ft's down to 2.2, you'd be up there in the low 9's at least. How are you launching?
Old Apr 25, 2010 | 02:41 PM
motomadness910
Pmd u jairen
Old Apr 25, 2010 | 07:57 PM
No need to post dyno charts and mods. These are trivial details. 2.3 seconds speaks for itself.
Who told you to run 25 PSI on street tires?
Don't be too hard on yourself. Poor staging pad preparation and 2.0 seconds is impossible. You need a real dragstrip with professional preparation.
Old Apr 25, 2010 | 08:15 PM
motomadness910
well i just thought itd post everything possible ha but as far as the tire pressure i read up and some people said 26 was good. so i thought id drop it but was that a bad idea to drop tire pressure?
Old Apr 25, 2010 | 08:41 PM
You can experiment; however, street tires are designed NOT to flex. I run 30-35 PSI on street tires. 25 PSI offers way too much rolling resistance.
Old Apr 25, 2010 | 08:59 PM
motomadness910
next time i go out ill be sure to experiment ill try and keep it around 30 then thanks david
Old Apr 25, 2010 | 09:08 PM
Good. Looking forward to you joining the Top-25.
Old Apr 25, 2010 | 09:27 PM
03threefiftyz
Keep one thing in mind when you lower tire pressure.....most do it as soon as they hop off the highway (longer drive) and enter the track. Dropping the tires to 25 psi when hot will likely be more than you wish to in reality. As the tires cool the pressure drops considerable.....that 25psi might be closer to 21 by the time the tires cool b/w runs.....particularly if the track is crowded. Happened to me last Dec....went into the lane with 15psi in the tires.....temps quickly dropped from 50's to 30's and several stoppages happened....causing a 90 minute delay b/w me entering the lanes and running. Thought about it just before hoping in to run and checked.....tires had dropped to 8-9psi. Had to abort the run.....there was no way to back out of line, etc....just cruised down the track at a cool 15mph. Also, general rule of thumb is every 10 degree drop in outside temperature will lower tire pressure by 1psi.
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
rizzla
Drag
Sep 17, 2015 08:44 AM
praxis
Feb 15, 2005 04:51 AM
