Drag NHRA, IDRC, IHRA, NDRA
2005 coupe 6MT 13.79 @ 103.5 with MILD bolt-ons
Old Jun 22, 2010 | 01:37 PM
Reidonly's Avatar
Reidonly
Originally Posted by slim17265
good morning Reidonly.....
I had Jesse look at my car last nite...he checked my settings with a lap top . although he seemed to be checking and changing alot of things he said he had only increased my timing by 2 degrees above stock....my car now is a totally different animal....I knew that the car was not performing like it should. First gear now literally charges and getting rubber on second gear shift...wow...anyone looking for additional power should look at this first...I am so happy with my car now...thank you so much for your help....
Excellent! I had him bump my timing up 2 degrees and do some datalogs a while back, and it did make a noticeable difference (seat of the pants at least). I need to get back to the track with the advanced timing and the 19's back on and see what she does.
Old Jul 1, 2010 | 05:46 PM
350z-Na's Avatar
350z-Na
update us once you go to the track again
Old Jul 1, 2010 | 06:05 PM
BonesZ33's Avatar
BonesZ33
Thumbs up
Originally Posted by ajcool2
Weight Reduction...it works lol.
troof
OP good times.. You have strong trap speeds, you could have a low 13 with a better tire setup and launch.. shed some weight too.. Thanks for the before and after with the HR y pipe.. Did you feel any difference when you put it on?
Old Jul 6, 2010 | 06:40 PM
Reidonly's Avatar
Reidonly
Thanks, I'm pretty happy with it considering my race weight is 3700lbs with between 1/8-1/4 tank of gas (yeah, I'm an ogre at 6'4" & 275lbs lol). I don't intend to shed any extra weight in the car, I always like to see how my cars run exactly like I run them on the street - pump gas, street tires, full interior etc. Only weight reduction is spare tire removed - but thats how I drive it all the time and I have done that with all of my cars before this as well.
I did notice a slight difference in exhaust note right off the bat with the HR y-pipe, a little bit deeper growl to it under load. After about 2-3 days of beating on it to get the ECU adjusted to it, I did notice a difference in seat of the pants feel. Although initially to me it felt like more of an increase in the lower end of the power band. I look at it like having a longer collector on a set of headers, which would traditionally give you more torque down low. Obviously based on the dyno, it was exactly the same power until 4500rpm or so where it picked up until redline. But yes, definitely a noticeable gain - not bad for a free mod lol.
Old Jul 13, 2010 | 01:16 PM
Nealoc187's Avatar
Nealoc187
nice traps, now work on the 60's
Old Jul 17, 2010 | 02:06 PM
Reidonly's Avatar
Reidonly
Installed MREV2, 5/16" iso-thermal spacer and Injen CAI last week, and today installed Kinetix resonated test pipes with de-fouler trick... w00t! I'll post up when I have updated track times or dyno.
Old Jul 18, 2010 | 10:12 AM
denchan350gt's Avatar
denchan350gt
when do you plan on going to cecil again? My best time there is 13.2 in my G. I ran that last dec.
Old Jul 18, 2010 | 12:03 PM
Reidonly's Avatar
Reidonly
Not in this weather. If we get a cool Wednesday night I might sneak down, but otherwise I don't plan to until later on closer to fall.
What all do you have done to yours?
Old Jul 18, 2010 | 03:28 PM
denchan350gt
I have every bolt-on except cams. I plan on installing ART pipes in a couple of weeks. I have a thread on my run on driver in the drag section.
I'm waiting until it gets cooler also like in sept. Let me know I've been there a couple of weds nights before in May.
The best I could do on my ET streets was 13.5@100. I did my 13.23 on street tires, but the weather was way cooler.
My SN is Dsskyline on driver.
Old Jul 18, 2010 | 06:58 PM
Reidonly's Avatar
Reidonly
Ah ok, I thought it was the same person. Yeah so now I have Injen CAI, plenum, spacer, HR ypipe, test pipes and +2 deg timing. The car pulls great with the test pipes now. We'll see how it plays out in reality, but I'd like to see a 13.5X @ 104-105mph. But I don't want to get ahead of myself.
Old Jul 29, 2010 | 05:42 PM
denchan350gt
come out to cecil this saturday a couple of us are planning are going since the track here opens late on saturday.
We should all be there around 10.
Old Jul 29, 2010 | 08:48 PM
Reidonly's Avatar
Reidonly
I'd like to, but I don't know if I'm going to have time. I have a lot going on Saturday. Tell you what, Monday night was AWESOME weather. Too bad it wasn't open then lol. Nice cool air.
Jambo016
Sep 16, 2016 01:08 PM
Stevo Z
Oct 3, 2015 09:14 PM
