Drag NHRA, IDRC, IHRA, NDRA
Hitting rev limit in 4th before the 1/4 mile, Options??
Old Jun 23, 2011 | 08:44 AM
djtimodj's Avatar
djtimodj
Default Hitting rev limit in 4th before the 1/4 mile, Options??
Guys im hitting the rev limit at 7000rpm in 4th gear about 30-40ft before the finish. Its quicker to stay in 4th and hit the limiter over the line than change into 5th but what can I do to help this??
Im on 18" 275/40 street tires at the moment and dont really want to run drag wheels and tires as I have OEM brembo's. I have looked at M&H 275/45/18 drag tire (28" tall) but im not sure if this will fit and may slow me down being that tall?
Any ideas guys as im not sure about reving a stock DE head set up past 7K rpm??
Thanks..
Also a 3.3rear end may slow me down to?? LOL.
Old Jun 23, 2011 | 08:47 AM
03threefiftyz's Avatar
03threefiftyz
I would try the taller tire first...
Old Jun 23, 2011 | 09:25 AM
The extra shift hurts ET. Taller tire. Different rear end.
Old Jun 23, 2011 | 10:35 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Taller tire. You need 28" because you are already at 26.7"
Increase limiter for 1st and 4th gear use only
3.3FD
Shift into 5th
Live with it
djtimodj's Avatar
djtimodj
You guys think a 28" will be benificial for me at 460whp? Or just slow me down?
Old Jun 23, 2011 | 09:42 PM
bacalhau16's Avatar
bacalhau16
With 460whp, a 28" tire shouldnt be a problem. It certainly wont slow you down as you are not even using the full potentional of 4th gear as it is now.
Old Jun 24, 2011 | 05:44 AM
djamps's Avatar
djamps
I ran with 7.5k redline without issues stock block, as long as you don't routinely bang the redline you'll be fine especially being built and all.
Old Jun 24, 2011 | 05:48 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Oh I kept thinking you were stock block, if you are built this shouldnt even be an issue. Get an extra 500rpm's tuned it her, and let her rip.
Shift at 7500rpm's on the 1-2 as well! This alone if you could get traction in 2nd would be huge for your time.
Tochigi_236
Sep 27, 2015 03:40 PM
