Drag NHRA, IDRC, IHRA, NDRA
No traction at the track
Old Apr 6, 2012 | 06:05 PM
AtomicX's Avatar
AtomicX
Default No traction at the track
Hey guys, I took my 350z to the track today for the first time, and I was having nothing but problems. Current mods are an intake exhaust and plenum spacer. For some reason, going down the track whenever I hit 3/4 WOT or WOT, the car lost traction and cut loose, very scary. This happened almost every time going down the strip besides the first time. After leaving the track as well at every stop sign my car was peeling out but it stopped after driving for awhile because the gunk from the dragway burned off.
How do I correct this for future drag trips, I would like to actually make a clean run down the strip.
Old Apr 6, 2012 | 06:45 PM
white boy's Avatar
white boy
What kind of tires and tread life?
Old Apr 7, 2012 | 05:34 AM
No time slip - no comment.
Old Apr 7, 2012 | 06:24 AM
AtomicX's Avatar
AtomicX
The tires are Nankang Ultra Sports with 75% tred life left. No Time slips posted because all were 18+ because I keept drifting around the drag strip.
Old Apr 7, 2012 | 06:35 AM
rawley_12003's Avatar
rawley_12003
Stay out of the water pit at the drag strip if you are. But recommend you post a time slip.
Old Apr 7, 2012 | 07:30 AM
AtomicX's Avatar
AtomicX
I went around the waterbox everytime. One of my last trials, I babyed 1st and 2nd (Shifted at 4k and barley 1/2 WOT). Then once in 3rd started giving it 3/4 throttle and the car just cut loose and went sideways.
Old Apr 7, 2012 | 08:20 AM
djamps's Avatar
djamps
Sounds like there was oil on the track, or it was otherwised prepped like total crap.. also could be your alignment. Eventually I got a set of dedicated track tires (ET streets) and it's so much more enjoyable.
Old Apr 7, 2012 | 08:23 AM
white boy's Avatar
white boy
was anoyone else having troubles with the track before and after you?
Old Apr 7, 2012 | 08:33 AM
eltness350's Avatar
eltness350
The Untouchable
invest in some better tires or a seperate set of drag tires to help this. with your mods some nice performance tires should hook better for u
Old Apr 7, 2012 | 08:42 AM
white boy's Avatar
white boy
tires will def help, but it still sounds like something was on the track like Djamps said, he should not be getting that loose in 3rd on only 3/4 throttle
Old Apr 30, 2012 | 02:24 PM
marra23's Avatar
marra23
check your wheel alignment
apex locator
Jul 23, 2021 02:27 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
