Drag NHRA, IDRC, IHRA, NDRA
Drag wheel & tire combo
Old May 16, 2012 | 04:42 AM
imkindafkedup's Avatar
imkindafkedup
Default Drag wheel & tire combo
So I'm going up to the drags this up coming sunday and because of the short notice I don't really have the time to get wheels shipped to me. I'm looking around locally for something that will fit my application. What are you guys running for a wheels and tire combo. The more info you can give me on your set up the better.
I've read the rx7 wheels were a popular choice for us Z's but haven't found any locally yet. Also, I think I'm pretty set on Mickey Et Streets because of how well they hook while still not putting as much stress on the drivetrain.
Old May 16, 2012 | 11:34 AM
Quamen's Avatar
Quamen
17" mustang wheels work as well.
Old May 16, 2012 | 08:34 PM
imkindafkedup
Thanks for the tip. They seem to be more common and can be found with drag radials much more often.
Old May 16, 2012 | 10:33 PM
Any 17 inch wheel with the same bolt pattern and offset will work. There is no ideal width. You can put a 265 mm ET Street on a 9.0 inch wheel. That should be plenty of rubber for your torque.
Old May 23, 2012 | 09:33 PM
Never mind. I thought this was important. Important enough to say “thanks” or simply reply.
Old May 24, 2012 | 07:58 PM
imkindafkedup
I was hoping to get some more responses of what people were running. I'm looking for a drag set up, so just a 17" wheel really isn't the ideal size. Its too late now since I already had the races this past sunday and was unable to get the right wheels in time, and as I expected hooking up was my problem with my 19" Volks. I'm considering just getting everything shipped now and will likely be going with 15x8 rears and 17x4 fronts since I'm not longer in a rush.
Old May 25, 2012 | 12:39 AM
OldManZ350's Avatar
OldManZ350
Weld ProStar 15 x 8's Rear with 27 x 10.5 Et Streets
Weld ProStar 15 x 4's Front with 26 x 6 Sportsman S/R
Attached Thumbnails Drag wheel & tire combo-p1010005.jpg   Drag wheel & tire combo-p1010002.jpg
Old May 25, 2012 | 04:36 AM
Frosty87's Avatar
Frosty87
[IMG][/IMG]
This is my temporary set up with rx7 16x8 wheels 275 55 16 m&h radial.
Old May 25, 2012 | 04:43 AM
OldManZ350's Avatar
OldManZ350
Originally Posted by Frosty87
[IMG][/IMG]
What did your car run in the 1/4 ?
Old May 25, 2012 | 05:47 AM
Frosty87's Avatar
Frosty87
Never got to run this setup down.the 1/4 although this pic is from 1/8 mile local event where I got a tuned and intake 2010 Gtr.
[IMG][/IMG]
Old May 25, 2012 | 05:53 AM
imkindafkedup
Now we're getting somewhere. Thanks for the responses guys. I didn't realize a 15 would fit on the fronts.
Old May 25, 2012 | 06:12 AM
str8dum1's Avatar
str8dum1
only if you have a 03/04 non-brembo or swap to 03/04 non-brembo brakes/rotors
AFter that the brakes/rotors got bigger.
Old May 25, 2012 | 06:24 AM
Frosty87's Avatar
Frosty87
If 07-08 have to run 17s in front
Old May 25, 2012 | 11:11 AM
imkindafkedup
good deal. As I expected. I have an 08.
Old May 25, 2012 | 11:49 AM
str8dum1's Avatar
str8dum1
you can still buy calipers and rotors from a 03/04 and mount them up to fit 15's.
Old May 25, 2012 | 01:01 PM
OldManZ350's Avatar
OldManZ350
how about your 1/8 mile ET and MPH ?
[IMG][/IMG]
Old May 25, 2012 | 02:38 PM
Frosty87's Avatar
Frosty87
I can tell you last year on my 18s with 285 40 nto5r tires got one pass before I blew both axlesi was at 484whp and had a crappy 2.0 60ft and ran a 11.95 @125 the event is just a win lose setup . I can tell you the new tire setup is way better for launching the extra sidewall made a huge difference.
Old May 25, 2012 | 04:45 PM
imkindafkedup
I'm already running dss pro axles so my worries about breakage are lessened.
Old May 31, 2012 | 06:25 AM
djamps's Avatar
djamps
Stick with tall sidewall bias ply tires (e.g. 26" tire on 16" or smaller rims) and you shouldn't be breaking axles. I have a very consistent 1.6-1.7 60ft on ET streets w/RX7 FD wheels and have yet to have any stock axle issues.
Old May 31, 2012 | 07:59 AM
Quamen's Avatar
Quamen
Agreed. 28.0x10.5x15 here running 1.510 60' on stock axles.
