Drag NHRA, IDRC, IHRA, NDRA
Hello high 11's!!!!
Old Feb 24, 2004 | 02:29 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally posted by themyst
the rear end isn't tightened too well at the factory. a few hard launches and the thing will start making a ticking noise. need to take it to the dealer to retighten. had that problem on my Z, starting to happen on the g35.
when you say "ticking" do you mean an audible "ticking" or somthing felt through the drivetrain??
Old Feb 24, 2004 | 03:13 AM
XBS's Avatar
XBS
Veteran
sorry what do u mean by "IRS"
Old Feb 24, 2004 | 08:30 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Independent Rear Suspension
Old Feb 24, 2004 | 08:56 AM
Klypto's Avatar
Klypto
When you say ticking, do you mean a creaking? cause i cant tell if its my rear end or my struts that keep creaking...
Old Feb 24, 2004 | 09:23 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Are you talking about on a 350Z/G35 or an F-body??
Old Feb 24, 2004 | 10:41 AM
Klypto's Avatar
Klypto
lol that was my friend...(Conceyted) he has 350z was just at my house
Old Feb 24, 2004 | 11:20 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
ah....ok...I was confused.
Old Feb 24, 2004 | 01:26 PM
92hatchattack's Avatar
92hatchattack
hmmmm ,.... i experience a creaking all the time when i shift, or let off the gas and accelerate again ..... is this the ticking we are talking about>?
Old Feb 25, 2004 | 01:49 AM
sith's Avatar
sith
After running my car at the track a few times i started to hear a little ticking/clunck when i would shift, let the clutch out and get on the gas.
Take it to your dealer they will fix it.
i can't remember exactly what it is but i know it's a Nut that comes loose on the rear end that they ahve to tighten up......It has to do with the DriveTrain.... They jsut re torque it and since then i've been back to the track on ET Street's and haven't had a single problem....
Old Feb 25, 2004 | 07:40 AM
92hatchattack
cool, i will do that then ... thanks!!!!
Old Feb 25, 2004 | 11:14 AM
jackie chan's Avatar
jackie chan
Originally posted by Alberto
You werent kidding when you said little puppies, those look narrow. Although they are much better than street tires, with the power your car makes you will probobly need wider slicks....good luck at the track and let us know how you do.
Old Feb 25, 2004 | 11:37 AM
daking350's Avatar
daking350
Originally posted by jackie chan
Old Feb 28, 2004 | 01:49 AM
turbojimmy's Avatar
turbojimmy
Originally posted by daking350
Swap em at the track..You can not drive on slicks..And its not a scratch its a reflection from the flash..
You can drive on slicks, it just makes the po-po unhappy.
I got tired of swapping things out at the track and picked up a pair of Hoosier Quick Time Pros. They're slicks with DOT-approved markings. They hook just as well as a real slick. Not good for corner carving, but save you from having to lug 2 sets of tires to the track and taking the time/hassle of swapping.
Jim
Old Mar 1, 2004 | 02:15 AM
Rob Nance's Avatar
Rob Nance
Originally posted by Conceyted
Alright, well if you guys come home with broken rear ends, all I will say is I told you do. If I were you guys I would not be running slicks on a stock rear end. Maybe I'm wrong and the Z has some amazingly strong rear end that can take the abuse. I hope I am wrong!
No offense, but 14.24 and a 2.2 sixty foot, do you have a lot of strip experience to be talking about rear end problems as a result of slicks? I'm just curious. I guess from what you're saying maybe you just went real easy for your quarter mile times?
Anyhow, someone doesn't put a supercharger or TT setup to worry about breaking stuff. The idea of putting slicks on a car and then babying it completely negates the reason for putting slicks on a car
Old Mar 1, 2004 | 04:08 AM
Conceyted's Avatar
Conceyted
I run back to back to back 14.2's with 2.2 60's. For some reason, the dragsters in front of me leaving patches of rubber down the track gives me less than optimal traction. I hook better on the street than I do at the track.
Bolting slicks up to a stock rear end can easily result in broken parts. I have seen it happen many times. I have been going to the strip for over two years now, maybe not the experience you have, but none the less I would not be bolting slicks up to my stock rear.
Old Mar 1, 2004 | 11:39 AM
nrc motorsports's Avatar
nrc motorsports
[QUOTE]Originally posted by Conceyted
[B]I run back to back to back 14.2's with 2.2 60's. For some reason, the dragsters in front of me leaving patches of rubber down the track gives me less than optimal traction. I hook better on the street than I do at the track.
this makes no sense.. are you sure your not just bogging if you run after a dragster? that would make sense..
if you walk on the track after a dragster runs your shoes will stick to the ***** you'd have a hard time walking, let alone spin your tires..
Old Mar 1, 2004 | 11:51 AM
Conceyted's Avatar
Conceyted
[QUOTE]Originally posted by nrc motorsports
[B]
I didn't bog a single launch. And your wrong, with all the rubber down the track your not going to stick more.... think about it.
Quit talking trash and post your 60' times in your Z on stock tires.
Old Mar 1, 2004 | 11:58 AM
  #38
nrc motorsports
your a little edgy huh... rubber on the track equals traction..
why do you think pro cars and funny cars do burnouts past the tree..then back up in their tracks you think about it jay
Old Mar 1, 2004 | 12:04 PM
  #39
UF350Z's Avatar
UF350Z
Alright it's march 1, you went to the track on the 28th....how'd it go?
Old Mar 1, 2004 | 12:15 PM
  #40
turbojimmy's Avatar
turbojimmy
He posted a new thread.....
Cliff Notes:
Has the MPH, not the ET. Needs traction.
Jim
