Drag NHRA, IDRC, IHRA, NDRA
10.39 @ 137 MPH ATCO Raceway, NJ
Old Aug 29, 2004 | 04:54 AM
bluefish's Avatar
bluefish
Default 10.39 @ 137 MPH ATCO Raceway, NJ
well the car is stronger and andrew showed what the Z could do with the correct set-up...
more details monday, and video soon...
first run
10.58
second
10.32
First Qualifiying run
10.39
Old Aug 29, 2004 | 04:55 AM
bluefish's Avatar
bluefish
http://ndra.nopi.com/eqraces/dsp_qor...0Street%20Tire
Old Aug 29, 2004 | 05:17 AM
bluefish's Avatar
bluefish
Default 10.32 @ 137MPH
http://ndra.nopi.com/eqraces/dsp_ere...0Street%20Tire
Old Aug 29, 2004 | 08:08 AM
Anthony Mantovani's Avatar
Anthony Mantovani
nice work boys! Looking forward to seeing some 9 sec slips in the near future. I know that things got a lot more in it than 10.3s, keep tuning. BTW hows that new mustang dyno, what were the #'s before this run? Good Luck
Old Aug 29, 2004 | 08:45 AM
jackie chan's Avatar
jackie chan
well that mph makes a lot more sense with the rwhp you said the car was putting down.
Old Aug 29, 2004 | 09:33 AM
95snoozer's Avatar
95snoozer
finally,, some badass times.
sorry i havent been following. I know you are on the bottle, but what is the bottomend built with?
Old Aug 29, 2004 | 09:41 AM
jackie chan
the bottle is long gone, they have moved to a built motor and turbo.
Old Aug 29, 2004 | 11:27 AM
95snoozer's Avatar
95snoozer
ah
well in that case, i wonder if a guy here will give you a run for your money.
on stock bottomend with minimal boost it went 12.2 at 118 on drag radials
he is breaking in the built motor and will run 17 pounds... almost 3 times what he was running.
Old Aug 29, 2004 | 08:04 PM
nrc motorsports's Avatar
nrc motorsports
when are you guys gonna put a glide or th400 tranny in that car? how much power is the car making now?
good times..
jay
Old Aug 29, 2004 | 09:51 PM
bluefish's Avatar
bluefish
Default update 10.35 @ 141MPH
it's late but i had to share.
We ran a 10.35 @ 141 MPH ....
jay the car makes about 625 WHP...
we hit the end of the line with the IHI / PE Turbo kit...
the engine and turbos get re-done for Texas.. more info in the morning
21 + PSI and the turbos held up for the three run...
still have to get the 60 foot down, (we are fitting much bigger tires) 60 foot was 1.86...
pics up monday, Video of the four weekend runs up by wednesday..
10.5
10.3
10.3
10.3 @ 141 MPH
good night all
Old Aug 30, 2004 | 05:47 AM
krismax's Avatar
krismax
Default Re: update 10.35 @ 141MPH
10.5
10.3
10.3
10.3 @ 141 MPH
good night all
That is great !
When i get a 350Z i'am coming to your place for some parts
Old Aug 30, 2004 | 05:57 AM
nrc motorsports
put an auto in that ***** and it will go right in the 9's....i love my supra with the th400 tranny...
jay
Old Aug 30, 2004 | 06:34 AM
jackie chan
yeah you just need to get it out of the hole. 1.86 ugh, i cut 1.9s on street tires. 140+ mph is awesome
Old Aug 30, 2004 | 08:22 AM
rubes's Avatar
rubes
hey everybody it's andrew. just wanted to give you all specifics.
jay, we are putting a th400 in the car, we're starting the work on that today actually.
our 60 ft' were alot better than that last run. we were running consitent 1.6s all weekend but on that last run we lowered the 2 step another 100 rpm but the track was stickier than expected.
out best 60 ft was 1.64
we are pulling a maximum of 22 psi with those little ihi turbos that come with the PE kit.
keep in mind this is a stock driveline. we have the tilton clutch but it's stock gearbox, stock driveshaft, stock rear, nismo lsd, and stock halfshafts. we switched from stock rubber to hard bushings in the rear (thanks 350evo.com) suspension as well as the subframe and it cured the problems we were havin breaking halfshafts.
other than that the car ran like a raped ape all weekend, if we could have gotten the 60ft down our et's would have been a helluva lot better but we're def makin the power as you can see by the MPH.
oh and by the way we just did a pull on the dyno about 20 mins ago to see what kind of power we were makin.
drum roll please.......................
670 rwhp at 6500
700 rwtq at 5000
check out the FI forums for more details, bluefish will be postin them.
thanks
Andrew
Old Aug 30, 2004 | 08:38 AM
jackie chan
nice
Old Aug 30, 2004 | 03:52 PM
nrc motorsports
whats the car weigh right now? i'm sure you got it down right above the class minimum....
the cars flying now, but it will really be moving once your leaving off a transbrake...if it does'nt start breaking rears and shafts(knock on wood)..
good luck with it..
jay
ps, how the progress on the other car coming?
Old Aug 31, 2004 | 09:01 AM
shaitiger's Avatar
shaitiger
Amazing times. Keep up the good work.
Old Aug 31, 2004 | 09:28 AM
VeeTec's Avatar
VeeTec
Yep, the 60 foot is the only thing keeping you out of the 9's.
I hit a 1.6, but averaged 1.7 60' times with my old 452 h.p. FD.
You should be able to hit a 1.4-1.5 with that kind of power.
TrboMike
North East
Sep 28, 2015 06:36 PM
CrowzRSA
Sep 21, 2015 04:00 PM
FromGtoZ
Sep 20, 2015 03:41 PM
T'S 350Z
Event Photos
13
Sep 17, 2015 12:55 AM
