Drift SCCA Formula Drift, Drift Showoff, Drift Session, Drift Day, D1 Grand Prix, Drift Nation
i wanna do donuts!
Old Jun 29, 2005 | 03:24 PM
de_only_Z_2_c's Avatar
de_only_Z_2_c
Default i wanna do donuts!
i have a 350 base no vdc no limited slip help!
i want to do donuts and drift to and from work
Old Jun 29, 2005 | 06:28 PM
doodeitstom's Avatar
doodeitstom
LOL, I bet you regret it now since you messed up your car.
Old Jun 29, 2005 | 10:20 PM
aaronlosey's Avatar
aaronlosey
get a nismo lsd, problem solved. all you need to drift a z.
Old Jun 30, 2005 | 01:18 PM
dank311's Avatar
dank311
practice, skill....and LSD
Old Jul 1, 2005 | 11:35 PM
nyc350z's Avatar
nyc350z
WERDDDD ! the nismo lsd def solved my problem.. i have it set on 2 way and 80% and it drifts so nice i freakin love my Z ! DRIFT ON !
Old Aug 17, 2005 | 05:26 AM
Vamos_Rafael's Avatar
Vamos_Rafael
LSD is just to put all the power down to the ground?
I got an enthusiast 350... it should be able to wreck some rubber then...
I never had RWD before :P please tell me ^^
Old Aug 17, 2005 | 08:07 AM
TiPIACE's Avatar
TiPIACE
does the Nismo LSD still produce axle tramp when the rears spin?
Old Aug 17, 2005 | 08:22 AM
aaronlosey's Avatar
aaronlosey
most of the time no, however sometimes yes. i'm not quite sure what does this, but its not all that often. i've burned off probably about 50 tires on the back of my z, at least. i've only encountered the axle hop about 3-4 times. i think you have it if you have too much traction on the rear end. i drift, so my tires are normally over heated and kinda slick, and i only run 245s in back. if your doing burnouts in water boxes or on hot tires, you should be fine. if your doing burnouts on the road with 295s, you might have axle hop.
i'm not really sure why it shows up on the z. maybe if you increase your spring rate or stiffen your shocks ( if you had coil overs or adjustable suspension ) it would get rid of it.
its a rough diff though, but great for drifting and putting down power.
:shrug:
oh, and as to the stock vlsd in the higher end z cars, they tend to be inconsistent, and not hold up to big beatings over the long haul. however, they are very quiet and don't clunk around, so they are a great inbetween diff. if you don't want to have a clunky diff, the stock ones are a good comprimise.
Old Aug 17, 2005 | 03:02 PM
misfit's Avatar
misfit
+1 I've drifted the stock and it gets the job done. Sometimes it's there and sometimes it isn't.
Old Aug 17, 2005 | 03:23 PM
monkey7's Avatar
monkey7
You still can do donuts with open diff, just take some practice. just turn the wheel, floor the gas and when you feel the back go out, countersteer, but not too much. Open diff drifting try using weight to start and continue drifts.
Old Sep 13, 2005 | 12:05 PM
Cali BlackTrack's Avatar
Cali BlackTrack
for dough nuts all u need to do is gas/brake and once it starts burnin out turn ur wheel and let go of the brake
Old Oct 26, 2005 | 05:29 PM
JERZ33's Avatar
JERZ33
Im looking to upgrade my enthusiast to the Cusco carbon LSD, but i think I should
  • Get tires
  • get wheels
  • get seat time
then maybe the lsd and some coilovers...
MAsSIVrOOM
Oct 20, 2023 10:50 AM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
sherm
Sep 10, 2015 11:02 PM
