Drift SCCA Formula Drift, Drift Showoff, Drift Session, Drift Day, D1 Grand Prix, Drift Nation
Bee-r rev limiter
Old Feb 10, 2011 | 05:58 PM
scrantonz33's Avatar
scrantonz33
just an example
Attached Thumbnails Bee-r rev limiter-1872350640a3779242597b435753667l-1-.jpg   Bee-r rev limiter-img_0658-1-.jpg
Old Feb 10, 2011 | 07:04 PM
Z_enthusiast's Avatar
Z_enthusiast
Originally Posted by scrantonz33
Not getting offended just alot of people are knocking this product but dont really know what it is. im not trying to be a pro drifter or anything but nearly every d1gp driver uses it. i have done the studies on it and all i was asking is if anyone knows how to install it. but apperantly its a lost cuase. i found the install in english very simple. thanks though for everyones opinions. no hard feelings.
so how is it installed? id like to hear a 2step in person on a z. maybe, my car lol
Old Feb 10, 2011 | 07:10 PM
o.g.darkdrifter's Avatar
o.g.darkdrifter
Not all D1 drivers use Bee*R but virtually all D1 cars use standalone engine management which usually uses the same method of ignition cut rev limiters. They also have engines that are much more aggresively tuned than a stock engine though.
Everyone has already said what needs to be said otherwise.
Seeing as how you have the part already I can see where you're coming from.
Old Feb 14, 2011 | 06:41 AM
Alberto's Avatar
Alberto
Cranky FI Owner
This is better for what you want it for. LOL @ "i have done the studies on it"
http://www.mimousa.com/home.asp?dir=products&prod=444
Dont end up like this guy OP
Old Feb 16, 2011 | 01:26 PM
scrantonz33
all right so this is how it goes, Red- power Black- ground Yellow- crank signal Green- ignition signal White- clutch switch/ hand brake switch depending if you want it for drift or wide open throttle. for the ignition signal u need a greddy ignition signal adapter, on the z it doesnt have a single point at the ecm to connect to the ign sig instead ther is 6 so the adapter takes it 6-1. have not fired it up because im doing a complete suspension build.
Old Jan 14, 2012 | 08:16 PM
threefittyz08's Avatar
threefittyz08
Default question on ign. signal adapter
Hey I saw that you have installed the limiter, also that you got the ignition signal adapter. is it this one? http://www.customcarscentral.com/gdy...al-nissan.html
and also how did you install it, I'm kind of new to the ign. signal adapter thanks
(correction i installed the power wire, ground wire, and the RPM wire. but still kind of confused)
Yellow- crank signal which is the CKPS POS on the image below?
And the ignition signal wire, only 1 comes out of the Bee*R unit which is green. But there are 6 Ignition signal wires, one for each cylinder. I see that you got the Greddy ignition signal adapter, but that even still has 6 yellow wires and one black? so where does the one ignition signal wire go from the Bee*R unit? thanks a lot if you can help or anyone else can.
Last edited by threefittyz08; Jan 16, 2012 at 04:32 PM. Reason: editing for more clarity.
Old Jan 17, 2012 | 03:22 AM
scrantonz33
Sorry i took so long to get back, been away from my350z that is the adapter and as far as i know it splices into the 6 ignition wires. i actually turned my z back to stock and bought a 240sx race chassis so i never finished installing everything. It was just too much of a pain. I dont know enough about automotive electrical so i hope maybe someone sees this and can answer youre question. good luck.
Old Jan 17, 2012 | 05:50 AM
threefittyz08
Thanks Its all good man its just you were the only one on here that has had experience with it so far that i know of. Okay yeah I'm not so much either but I'm gonna try to get through this one, but a shop down here is going to see what they can do they were a little stumped also, good luck with the 240.
Old Sep 1, 2013 | 02:20 PM
Keith Reading's Avatar
Keith Reading
did anyone ever figure this out? im still trying to install one on a vq35
Old Sep 26, 2013 | 07:10 PM
booozy's Avatar
booozy
Same here. How come nobody has done this to 350s?
Old Oct 5, 2013 | 04:09 PM
DTown's Avatar
DTown
Buddy,
I Would ASK if you or any Otter One here has a pinout for my japanese z
Because all the Pics of the ECU pinout are different....
I Need to find the 6 Ing and the rpm on my One :-(
Old Oct 30, 2013 | 11:13 PM
Keith Reading
i still havent figured it out and no shops will touch it around my area. ive tried to contact bee r directly with no reply
Old Nov 13, 2022 | 09:30 AM
Jesse Curbow's Avatar
Jesse Curbow
Default Hey so did anyone ever install this on a 350??
I am not trying to fry my ecu but splice the six ing wires to one. Maybe a fuse idk does not seem difficult but one fell in my lap. These are old someone’s has to have installed on a Z or G. Any help much appreciated!! Be safe out there!!
Old Nov 13, 2022 | 11:05 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Interestingly, still available so how bad could it be? <Laff>
And everyone, including the reseller, Nengun, refuses to own its installation. (Although I do see it's sold by a number of resellers. Might want to consult with them too.)
Would suggest you check around with tuners local to you about it.
J 0 K 3 R
Sep 12, 2011 08:29 PM
ZjonZ
Nov 30, 2006 12:13 PM
Dissolved
Apr 15, 2004 10:15 AM
OBleedingMe
Jan 9, 2003 05:59 AM
