NEW South Bend Clutch DXD Solid 1 Piece Billet Steel Flywheels! The best!
Vendor - Former Vendor
South Bend Clutch DXD Solid Billet Steel LW flywheels!!
The ONLY flywheel other than stock that will not degrade driveability nor will they add the unwanted drive train/trans gear chatter noise associated with other LW aluminum flywheels.
These are lighter than the stock unit, Are far more durable than any aluminum inserted flywheel (no expensive to replace warped steel inserts here) If you drag race, track or just drive on the street you will LOVE this flywheel!
Because most of the weight has been taken from the circumference of the this flywheel you still get the advantages of less rotating mass while keeping the quite, stock like drive ability. Replaces Stock Dual mass flywheel in all 2003-2006 Nissan 350Z and Infiniti G35, Also have these available for the HR engines as well!
Buy now at ZSpeedPerformance!
Very interesting and looks like a good product. I would have totally bought this when I bought my Southbend OFE Stage3 clutch last year, but ended up with the discontinued UR one instead.
Have you drive with the UR one before and if so how does it compare?
The DXD Flywheel is a bit heavier so it definitely is easier to drive esp with an aggressive clutch material, Also much quieter over the LW aluminums as far as the input shaft rattle the 350 is known for.
Billet steel will absorb the heat and dissipate it better than the hardened steel insert in the JWT, fidanza, UR ect. With those all the heat builds up on the surface and the only place it has to go is back to the disk shortening its life span.
