FS: QUAIFE 60G 6speed Sequential Transmission (two!)
Old Apr 18, 2012 | 06:30 PM
Topics II's Avatar
Topics II
Default QUAIFE 60G 6speed Sequential Transmission (two!)
I have 2 Quaife 6speed straight-cut sequential transmissions for sale. They are both freshly inspected and freshened up with only a few run hours on each one. These transmissions are the best transmissions I have ever used but I am selling them because I am switching to a GForce 4speed. I have never had a misshift with these and hate to sell them.
This transmission comes with a Z33 bellhousing that utilizes a external slave cylinder for easy maintenance. Bolts right onto your VQ!
Ratios:
1st 2.769
2nd 2.057
3rd 1.579
4th 1.260
5th 1.104
6th 1.000
$7500 each
Old Apr 19, 2012 | 09:39 AM
Crom's Avatar
Crom
2 ?.... so tempting...
Old Apr 19, 2012 | 09:46 AM
350z006's Avatar
350z006
Baller!
Old Apr 19, 2012 | 09:54 AM
350zjason350z's Avatar
350zjason350z
Know it all
would these use your existing clutch and flywheel .... im not sure how this trans works ... but i know what it does ..
Old Apr 19, 2012 | 10:54 AM
Topics II's Avatar
Topics II
yes, it utilizes whatever clutch and flywheel you have on your VQ. The input shaft on this is matched up to the factory transmission size so no need for a custom clutch!
Old Apr 19, 2012 | 11:31 AM
Kwame's Avatar
Kwame
Dope
Old Apr 19, 2012 | 11:48 AM
ocdz's Avatar
ocdz
Free Bump! I thought these only existed in my dreams!
Old Apr 19, 2012 | 12:08 PM
06blueZ's Avatar
06blueZ
does this have reverse? cool
Old Apr 19, 2012 | 12:13 PM
03threefiftyz's Avatar
03threefiftyz
Do want. If it were the end of the year, and I were going to bump up in class (making this legal)...I'd be all over this.
Old Apr 19, 2012 | 12:51 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
hmmmmm
Old Apr 19, 2012 | 01:27 PM
0jiggy0's Avatar
0jiggy0
Wow. Not to go ot but any chance you can make a thread on your car. Would love to see what car these were in.
Old Apr 19, 2012 | 01:54 PM
Topics II's Avatar
Topics II
Yes, these do have reverse.
Old Apr 19, 2012 | 02:06 PM
Junkster's Avatar
Junkster
Provided his FB link, its chris forsberg?...still curious to know what Z it came out of, i know this didnt bolt up to the titan block
Old Apr 19, 2012 | 04:31 PM
i.rashid's Avatar
i.rashid
If this fits like stock, he was probably using an adapter plate on his vk to mate to a stock z33 transmission.
Old Apr 19, 2012 | 04:47 PM
SDGenius's Avatar
SDGenius
so sick
Old Apr 20, 2012 | 01:01 AM
Nismomonkey's Avatar
Nismomonkey
I feel like I will get laughed at for asking this, but how does it work exactly? Ive heard tell about these but never actually seen one.
Edit: According to google, just like a motorcycle gear box but for a car? pretty sweet. No gear hopping though I guess. Do you use something to let you know what gear you are in since they are all in a row and I imagine the orientation of the shift lever doesnt help?
Old Apr 20, 2012 | 03:07 AM
03Z33's Avatar
03Z33
This is the gear indicator. It's a LCD light that tells you what gear is selected by displaying a number 1-6. No skipping gears, you go through them in order just like a bike.
Old Apr 21, 2012 | 09:58 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Wow.
<--- King of Understatement
Old Apr 22, 2012 | 12:39 AM
Kwame's Avatar
Kwame
OP what modficatioms are necessary to get this to fit and operate properly in a stock Z?
Old Apr 22, 2012 | 06:33 AM
Topics II's Avatar
Topics II
You will need to make a transmission mount, driveshaft (which I will provide the yoke for), and modify the shifter hole for the shifter to fit through the tunnel. Otherwise, the bellhousing bolts on and allows you to run your full 350Z clutch with no modification.
